tutorial 17
Old   May 21, 2009, 10:26
Default tutorial 17
Mirko
painterwolf is on a distinguished road
I'm studying tutorial 17 because I need fortran subroutine for another project. I have problem with theese steps:
  1. Type the following command in the Command Editor dialog box (make sure you do not miss the semi-colon at the end of the line):
  2. ! system (“cfx5mkext TStat_Control.F”) < 1 or die “cfx5mkext failed”;
    1. This is equivalent to executing the following at an OS command prompt:
  • The ! indicates that the following line is to be interpreted as power syntax and not CCL. Everything after the ! symbol is processed as Perl commands.
  • system is a Perl function to execute a system command.
  • The < 1 or die will cause an error message to be returned if, for some reason, there is an error in processing the command.
  1. Click Process to compile the subroutine.
    Note
    You can use the -double option (i.e., cfx5mkext -double TStat_Control.F) to compile the subroutine for use with double precision ANSYS CFX-Solver executables.
A subdirectory will have been created in your working directory whose name is system dependent (e.g., on IRIX it is named irix). This sub directory contains the shared object library.
The problem is A subdirectory NO will have been created in your working directory
Which error I'm committing?
painterwolf is offline   Reply With Quote
Old   May 21, 2009, 13:28
Martijn
Martijn is on a distinguished road
I don't understand your problem. Could you be any more specific?
What happens when you process
!system (“cfx5mkext TStat_Control.F”) < 1 or die; ?
Martijn is offline   Reply With Quote
Old   May 21, 2009, 13:34
Mirko
NOTHING!! The subdirectory should be created there isn't in my working directory
Old   May 21, 2009, 13:38
Martijn
Does it give an output in the command window?
Did you install a fortran compiler on your system?
Old   May 22, 2009, 03:26
Mirko
In my sistem I installed visual studio 2008 and after I installed visual fortran compiler 11.0.072.
When I launch !system (“cfx5mkext TStat_Control.F”) < 1 or die;
I read:
Use of uninitialized value in pattern match (m//) at (eval50) line 1.
And if I reply command I read:
Use of uninitialized value in pattern match (m//) at (eval51) line 1.
and after
Use of uninitialized value in pattern match (m//) at (eval52) line 1.
etc etc
Old   May 22, 2009, 06:00
Martijn
Only some compilers are known to work in combination with CFX. These should work (maybe a few more, not sure though): Intel fortran compiler 9.0, 9.1, 10 and 10.1, Compaq visual fortran 6.6(?).
I guess thats your problem.
Old   May 22, 2009, 06:10
Mirko
Where I can find a trial version for one of theese FORTRAN versions?
Old   May 29, 2009, 18:22
Mirko
Is there someone can show me I can run tutorial 17? The command cfx5mkext d0n't work.
Old   July 14, 2009, 22:11
Thumbs up
Jack
rogbrito is an unknown quantity at this point
Files of this Tutorial:
http://www.4shared.com/file/72198900...tionpart1.html
http://www.4shared.com/file/72199871...tionpart2.html
    Note
rogbrito is offline   Reply With Quote
Tutorial for subcooled nucleate boiling Asghari FLUENT 42 December 10, 2018 11:42
Problem on Fluent Tutorial: Horizontal Film Boilig Feng FLUENT 2 April 13, 2013 05:34
STAR-CD Tutorial shekhar aryal STAR-CD 4 March 22, 2010 03:25
tutorial 6 in Fluent 6.2 tutorial and Mesh pilli4u FLUENT 2 April 2, 2007 05:09
Rotor/stator tutorial, and how to... gilberto CFX 5 January 21, 2002 09:41
