Velocity Loss Models
Old   May 25, 2009, 08:27
Default Velocity Loss Models
KRSU
KRSU is on a distinguished road
Hi All,
Could you please help me to expalin the difference between the superficial and true velocity loss models?
How that affects my results for my given volume porosity and loss co efficients?
Thanks in advacne!
KRSU is offline   Reply With Quote
Old   May 25, 2009, 10:50
Default Porous Model
KRSU
Hi All,
I will be grateful if you can help me about the following:
1. I am using the Volume poros model to model the car radiator. For that, I have Pressure drop cuve by wind tunnel experiments. I have found linear and quadratic co efficients also by curve fitting method. Then, from the CAD drawing I found the volume porosity as well. Kindly suggest me how can I get the exact porous model of the car radiator.
2. Whether should use Tru velocity or Superficail Velocity if I use Isotropic loss model?
Thanks in advance!
Old   May 27, 2009, 01:09
KRSU
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Old   May 27, 2009, 01:20
KRSU
Dear CFX Users,
Moreover, kindly let me know whether should I use Momentum source also?
Thanks and regards
Old   May 28, 2009, 21:10
Bharath kumar
bharath is on a distinguished road
hi,
1)if u haven't tried the tutorial try to do it first.
2)you can use both superficial and true velocity models.it depends what velocity you used, when you use to calculate resistance coefficients.
3)if u need just the pressure drop only you go for loss models.or if u need the velocity variation across the porous media you go for other models.
bharath is offline   Reply With Quote
Influece of wall velocity in the main flow marvin CFX 0 March 22, 2008 02:05
Gravity Flow Velocity Computation Jerry McHugh Main CFD Forum 1 March 16, 2007 13:24
How to deifmne head loss co effcint ? Angelina FLUENT 1 February 8, 2006 09:41
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
Convection velocity of Coherent structures Jongdae Kim Main CFD Forum 3 February 5, 2002 04:04
