CFX gravity driven free surface flow tutorial |
July 17, 2009, 02:33 |
mechovator
Rep Power: 17 |
Dear friends
I am working on water flow through dam. I want to simulate gravity driven free surface flowin the dam. but i am not able to find any tutorial related to the topic this is my email mechovator@yahoo.com can you kindly send me a tutorial about how to model a gravity driven free surface flow. It will be of great help to me. Regards Mechovator |
July 17, 2009, 13:49 |
Michael P. Owen
Rep Power: 17 |
What about the free surface flow over a bump tutorial?
July 17, 2009, 22:01 |
Jack
Rep Power: 16 |
July 19, 2009, 12:53 |
mechovator
Rep Power: 17 |
yes but that is not a gravoty driven flow... how will I model a multiphase gravtiy driven free surface that tutorial I need..... and to be more specific I have to add sedimentation effects... i.e. soil flow..... so kindly do tell me if you have any such tutorial. related to just gravity driven flow or sedimentation
July 19, 2009, 19:16 |
Free surface modeling
Sher
Rep Power: 16 |
Hi mechovator,
I am also solving a similar problem as your on CFX 11. I am modeling a rectangular tank (a mini dam). I am wondering how to model its free surface. If you have solved your problem then please advise me and also help me how to model its free surface, please |
July 20, 2009, 09:08 |
Once again, see Tutorial 7 (Free Surface over a Bump).
If you have done this tutorial, I still don't understand where you are having difficulties! What don't you know how to do??? Try to ask more precise questions.
Rui |
July 20, 2009, 18:45 |
#7 | |
Craig Hildreth
Rep Power: 17 |
Remember,you are talking to engineers. Poor grammar, spelling and not even taking the time to capitalize a sentence shows you probably haven't taken the time to think the problem through either. |
July 21, 2009, 12:28 |
mechovator
Rep Power: 17 |
Ok i will when i will get the solution
July 21, 2009, 12:54 |
#9 |
mechovator
Rep Power: 17 |
Dear Rui. I went through your thesis. Learned alot from it. I have decided to model steady state water flow first. I have no interest in simulating the free surface, neither do I need its behavior. I just want to give free atmostpheric boundary condition (ambient pressure of 1 pa)to upper surface of the water like there are for inlet, outlet and wall etc. I went through the free surface tutorial.
July 21, 2009, 12:58 |
Solution will be more appretiated than comments
#10 | ||
mechovator
Rep Power: 17 |
It would have been gr8 if u had a solution 2 the problem. Just commenting on the grammar without understanding the problem and giving no solution is like ..... |
July 21, 2009, 15:11 |
#11 |
Ok.
I'm sorry to say this, if it is not your case, but recently there are a few people posting here that, to be honest, they seem to me to be just joking. And, to be honest again, for their own good ... I hope they're.
Rui |
July 21, 2009, 16:28 |
#12 |
George
Rep Power: 18 |
mechovator, your tone is disgusting especially when trying to ask help from people for free. if one check your posts you have not contributed at all to this community and in most of your posts you continuously asking for someone to send you data/files/tutorials etc. You say you are a student and started an MS course, your university should had provided you with the software together with lectures/tutorials for you to study. I simply dont believe you and and I especially dont have time to spend for the likes of you, so I can tell you form now dont expect any help at least from me...
Top 4 tips 1. Knowledge is everything and Ignorance is dangerous. 2. Understand your limitations and try to eliminate them. 3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window. 4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials |
July 21, 2009, 18:46 |
#13 |
Rep Power: 143 |
Ok everybody, let's get back to the topic. I think the point has been made so let's move on.
If you want a simple model of the free surface then won't a opening set at atmospheric pressure do the trick? A bit of flow will go in and out but if you don't care about that then it sounds pretty simple. It might be a convergence issue as pressure boundaries don't like flow going in/out at angles - I think the entrainment condition may help here but I have never used that option so can't be sure. Glenn Horrocks |
July 21, 2009, 19:48 |
Free surface modelling IN CFX 11
#14 |
Sher
Rep Power: 16 |
Hi everybody and specially RUI,
First of all I would like to thanks Rui for his/her great contribution to this community on this forum. I am modeling a free surface problem and according to the suggestion of most of the ppl on this forum I tried Tutorial 7 But I could not successfully apply to my rectangular tank which I am modelling on CFX 11. My Boundary conditions are as: Inlet = Inlet with VolFair = 0, VolFwater=1 outlet= outlet with static pressure = uppres= density of water*g*VolFwater(upH-y) Top=opening with VolFair=1 and VolFwater=0 and static pressure=0 others BC are walls. If I model outlet as a outlet, then solver gives a message that 100% area at outlet is covered by a wall and if I model outlet as opening then the flow becomes reverse (from outlet towards inlet.). Please somebody help me in this regards. Specially I would expect to hear from Rui. Cheers |
July 21, 2009, 21:08 |
#15 |
George
Rep Power: 18 |
sher, without posting the domain and expressions ccl thre's little to say really. for example you didnt define what is your physical representation of your inlet and outlet perhaps a drawing and the model ccl?.
from what you wrote one would assume that for your inlet you have only water.. obviously the model depends on what your geometry is, however if I was to model a dam, air velocity and the effect of air to the water flow would be negligible therefore can be regarded as zero. if this is the case you have, you need to think how to express this relations as an inlet boundary the top boundary can also be modeled as a simple free slip condition. from what you said the outlet definition is wrong, you have forgotten to include the air in your hydrostatic relations. check again the said tutorial, most of your answers are there.
July 22, 2009, 01:50 |
Free surface modeling in CFX
#16 |
Sher
Rep Power: 16 |
Thanks ckleanth for your reply on my problem,
Can you please advise me how to post the .ccl file and the geometry. Actually I am new on this forum and need your help to know how I will make attchments. Thanks |
July 22, 2009, 01:58 |
#17 |
mechovator
Rep Power: 17 |
My tone will be like that if some one does not help and just comment. Not helping is one thing and commenting and being personal is another and you should also avoid that mr. You did the same thing. Elders should behave like elders. It's not that you can help or not or you don't want to. It's the way you are talking to a person. Morality and self respect is much more to me than grammar and profession.
July 22, 2009, 02:01 |
#18 |
mechovator
Rep Power: 17 |
Thank you ghorrocks. Am trying to refine mesh these days and will surely contact you when i again get back to boundary conditions.
July 22, 2009, 04:34 |
#19 | |
George
Rep Power: 18 |
in this forum you could also attach pictures or screenshots and zip files (in which you could attach a small 2D cfx or def file - I think there is a limit on the size you can attach though)
July 22, 2009, 07:20 |
#20 | |
Sher
Rep Power: 16 |
So many thanks for your help.I have uploaded the .CCL file of my CFD problem. Actually I am modelling a rectangular pond which have circular Inlet and Outlet at opposit ends. I am using CFX11 to model its hydrodynamics and want its top to model as free surface. I have again studied tutorial 7 and it seems that my expressions are according to that tutorial. But the flow pattern that I got is amazing and beyond the true pattern. Can you please advise me that what should i change in my .ccl file to get a good result. Also, I will appreciate your help if you please advise me how can I make my mesh a structural mesh. The previous mesh which I use is the mesh which CFX11 give us bydefault. I again thanks for your so nice advice and help. Cheers |
cfx, free surface flow, gravity driven, tutorial |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
tutorial : free surface flow over a bump | HAYATE | CFX | 1 | December 18, 2007 16:11 |
Multiphase flow. Dispersed and free surface model | Luis | CFX | 8 | May 29, 2007 18:13 |
Free surface vortex flow | Guillaume | CFX | 3 | August 25, 2005 20:52 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
