CFX - Compressor Impeller
Old   September 3, 2007, 05:53
Default CFX - Compressor Impeller
Dothan
Hi, I'm studing a centrifugal compressor impeller and I found some problems about BCs:
1 - Turbogrid define 2 surface, Inlet e Outlet surface; I think these surface serve to CFX-Pre for define the BCs. Unfortunately if I move the Outlet surface the solution change. Is better to fix outlet domain close o far from trailing edge?
2 - I know that "inlet pressure/outlet mass flow rate" and "outlet pressure/inlet mass flow rate" are most robust BCs, but my model converge only with "pressure inlet/pressure outlet".
3 - CFX-Post report a summary table with many variables @Inlet,@LE,@TE,@Outlet. I've noticed that Ttotal@TE<Ttotal@Outlet. Ttotal must change only inside the impeller...
many thanks for replyes
Old   September 3, 2007, 05:56
Default Re: CFX - Compressor Impeller
Dothan
Errata corrige: 3 - CFX-Post report a summary table with many variables @Inlet,@LE,@TE,@Outlet. I've noticed that Ttotal@TE < Ttotal@Outlet. Ttotal must change only inside the impeller...
Old   August 8, 2009, 07:44
cool_dude
cool_dude is on a distinguished road
hi it' s better to place the outlet surface away from trailin edge.,to avoid any variations in results (due to flow fluctuations)
If u want that extende surface to be excluded from rotating domain...
u can use primitive region and select that patch alone (give th BC as Counter rotating wall) --- this will be to prevent that extra patch from addin additional momentum to fluid..
cool_dude is offline   Reply With Quote
[ICEM] Proper way to name boundaries on 2D model for use in CFX? RossFS ANSYS Meshing & Geometry 4 November 10, 2011 02:38
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 13:22
PhD using CFX Rui CFX 9 May 28, 2007 05:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
