Flow over rotating sphere
Old   August 11, 2009, 03:57
Default Flow over rotating sphere
mistry
csmistry is on a distinguished road
Hi all
i want to do analysis of flow over rotating sphere.problem is:
to specify rotating domain in CFX Pre i found when i specify sphere as solid domain it is not giving be rotaion option when i specify fluid domain it only gives me option how to solve problem...
secondly i think SST model is best for the selection any suggestion?
how to specify FSinterface... here
Please guide me.
csmistry is offline   Reply With Quote
Old   August 11, 2009, 08:16
Assuming you are modelling flow over a rotating sphere with a known velocity then forget about solids, rotating domains or multiple domains. Just have a single domain with the sphere cut out of it. To impose the sphere rotation give the sphere walls a tangential velocity. I think the easiest way to apply this velocity is using a CEL expression to give velocity on the sphere surface as a function of XYZ location - this is easy providing the sphere location is known and the rotation rate is known.
As for which turbulence model is best - that depends on what you are trying to get out of the model and what Reynolds number and Mach number you are running at. SST is a good general purpose one but there are cases when it is not appropriate.
Old   August 11, 2009, 09:02
Default Rotating sphere
mistry
Sir,
Really your quick reply energied me do continuous work on CFD...
may i get any hint how to specify rotational velocity using CEL on sphere surface. my idea is to specify inlet region velocity need to specify.
My inlet velocity is 3 m/s and diameter of sphere is 1,1.5 m ,rotational speed 100rpm,150,200 and want to study pressure,velocity distribution on outer surface.
please Guide me.
Old   August 11, 2009, 19:07
As I said, it is a pretty basic CEL expression to give the sphere a rotating wall. You should be able to derive the expression yourself once you understand the basics of CEL. Have a look in the tutorial examples for some examples of how to use CEL.
superSonic Flow around sphere prapanj OpenFOAM Running, Solving & CFD 0 March 17, 2009 01:20
Flow around a sphere and a circular cylinder Francis Main CFD Forum 0 September 29, 2008 05:16
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
secondary flow in radial rotating pipe arash Main CFD Forum 0 January 20, 2002 13:49
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
