ERROR #001100279 has occurred in subroutine ErrAction.
Old   August 19, 2009, 00:23
Default ERROR #001100279 has occurred in subroutine ErrAction.
Thanathat
P9408 is on a distinguished road
Hi All
I have the error message as below any body help please....
My Problem have 8 CPUs with motor design anlso have a
area for rotating but for the first iteration have error as belo.
OUTER LOOP ITERATION = 1 CPU SECONDS = 1.054E+02
| Equation | Rate | RMS Res | Max Res | Linear Solution |
Parallel run: Received message from slave
Slave partition : 8
Slave routine : ErrAction
Master location : RCVBUF,MSGTAG=1012
Message label : 001100279
Message follows below - :
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Floating point exception: Invalid number |
Slave partition : 8
| Message: |
| Stopped in routine C_FPX_HANDLER: |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
| The following user files have been saved in the directory |
| D:\Mongkol\Motor\Motor_1_002: |
| mon |
This run of the ANSYS CFX Solver has finished.
P9408 is offline   Reply With Quote
Old   August 19, 2009, 07:56
This looks a little unusual but I suspect the root cause is merely a rapidly diverging simulation. Check the simulation is correctly setup and improve its stability and it should start up.
Glenn
ERROR #001100279 in subroutine ErrAction Stephan CFX 18 October 14, 2019 17:15
ERROR #002100013 has occurred in subroutine Chk_Sp Forrest CFX 4 August 2, 2017 18:59
ERROR #001100279 has occurred in subroutine ErrAct Yijin Li CFX 1 December 1, 2008 16:21
ERROR #001100279 has occurred in subroutine ErrAct Mohamed Musthafa CFX 0 September 29, 2005 08:41
ERROR #001100279 has occurred in subroutine ErrAct Carl CFX 2 July 16, 2005 14:39
