CFX from the command line
Old   September 8, 2009, 06:38
Default CFX from the command line
cfxmar is on a distinguished road
I´m trying to execute CFX from the command line. I have seen how to use cfxsolve, cfxstop...but I don ´t find a command to say CFX to save graphs or particular results you are interested in (for example, forces in an specific boundary), when the running finishes.
Any ideas?
Thank you in advance
cfxmar is offline   Reply With Quote
Old   September 8, 2009, 09:39
SanS
sans is on a distinguished road
hi, Are you referring to the residual plots and monitor points? And you would like to save these as plots?
I not sure if we require so much of automation.
Once your run is complete you may go back to the SM and open the results using the monitor finished run option. This would give you access to the residuals and other info.
sans is offline   Reply With Quote
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
Importing solutions in CFX. Alphonso CFX 1 August 1, 2008 14:01
PhD using CFX Rui CFX 9 May 28, 2007 05:59
CFX 10's solutions differ from CFX 5.7's Atit Koonsrisuk CFX 4 July 26, 2006 11:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
