A problem about density in liquid air definition |
May 12, 2011, 21:29 |
GARY JANE
Rep Power: 15 |
Hello Forum,
I have a problem. I want to simulate an liquid air turbine.Here i have to define a new material: liquid air at 95-105K. There is a problem:when the density is set to a constant value or values dependent on p(pressure),the solver can simulate it.But if it is set to a function related to p and T, the solver make errors. ----------------- the density definition is: (837.336029[kg m^-3]+(4.927578[kg m^-3 K^-1])*T-(23.125020[kg m^-3 Pa^-1])*(p/1000000)-(0.056504[kg m^-3 K^-2])*T^2+(0.287167[kg m^-3 K^-1 Pa^-1])*(T*p/1000000)-(0.221818[kg m^-3 Pa^-2])*(p/1000000)^2) ----------------- the error shows: Fatal bounds error detected --------------------------- Variable: Density Derivative wrt Pressure at Constant Temperature Locale : R1 ----------------- I have read the help and the help shows below: Density and Specific Heat Dependencies For a pure substance, the flow solver only allows density and specific heat capacity to be functions of temperature or pressure. When you select the Value option for density or specific heat capacity, you can use an expression to specify Density and/or Specific Heat Capacity, but the expression is only allowed to depend on pressure and temperature for liquids and gases. For a solid, they can depend on temperature or spatial location (x, y, z), but not both at the same time. For ideal gases, the density is evaluated using the Ideal Gas law and the specific heat may be a function of temperature only. Both density and specific heat capacity can also be a function of an algebraic additional variable, but the algebraic additional variable must only be a function of temperature and pressure. ANSYS CFX-Pre will not allow you to set this and you must therefore edit the CCL file to implement such a case. If density, specific heat, or other properties are set as expression which depend on pressure, the solver automatically uses the absolute pressure when evaluating the expression. ----------------- I think the definition is right but I can't find what is wrong... I am using turbulence: SST.... buoyancy : no buoyant Any help or advise would be appreciated..... Thank you very much! |
June 14, 2012, 04:31 |
Sebastian
Rep Power: 15 |
Hello alloveyou,
i have the same problem simulating a cavitative model. did you check your table generation in the material definition? well, as i imported your expression, i notice that your density is negative for some high pressure values about p = 8e+07 Pa. this could be one reason for the error, because the solver checks the density value for a high range of pressure. so check your density equation in the range of your table generation in material definition. however, did you solve this problem? please let me know how you did fix it. kind regards Sebastian |
June 14, 2012, 14:20 |
Sebastian
Rep Power: 15 |
hi there, its me again,
i think it is useful to have a CEL function for the density that can be derivated for gradients. so i tried a tanh as a function (derivated 1/cosh^2 and still continuous) of p to implement my blending situation between two densities in one single fluid material. it works fine and the error message did not appear up to now. but have a look on your table generation as well. |
meterial density |
air problem | fba | FLOW-3D | 4 | April 15, 2015 01:06 |
Density UDF for compressible liquid flows | KamilSobczak | Fluent UDF and Scheme Programming | 1 | July 15, 2010 07:32 |
Airfoils and lift compared to air density and TE | Jens | Main CFD Forum | 0 | May 4, 2006 03:31 |
can we Simulate air bubble inside hot liquid | Mohan | FLUENT | 0 | December 15, 2005 14:22 |
Density of liquid Sapphire as function of temp. | J.W.Ryu | FLUENT | 0 | September 8, 2003 02:24 |
