Isosurface creation
Old   October 20, 2009, 03:33
Default Isosurface creation
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
Hi all,
I want to create isosurface with variable "velocity (value=0 m/s)" to study the detachments in the flow. But I can't see the results in cfx post because the generated surfaces are "behind" of the wall(where the velocity is zero). How can I plot the detachment zones?
Sorry for the beginner question
Thank you,
Attesz
Attesz is offline   Reply With Quote
Old   October 20, 2009, 04:54
Matthias Voß
mvoss is on a distinguished road
hi,
When i am supposing your simulating a tube or smth. simillar... you could define a new variable via the "if"-command (if vel=0 AND diameter<max.Radius,...), if you´re using WB2.0/ CFX12.0
In CFX 11 try the same approach with the step-function.
neewbie
mvoss is offline   Reply With Quote
Old   October 20, 2009, 05:40
I think you will find that an isosurface of V=0 does not adequately show recirculations in 3D, even when you have removed the wall surface. There is plenty of research around about how recirculations are defined and how to find them in 3D - it is not as easy as it may first appear. Other variables which can be useful include vorticity, but it depends on a case by case basis.
I think CFX also has a new feature in V12 designed to detect vortex cores. I have never used it so have no idea how useful it is, but maybe you should consider it.
I would recommend looking at streamlines as the simplest approach, and having a read of the literature for a more complete discussion of the current thinking.
isosurface
volume and mass exist in isosurface in CFX eslam CFX 2 June 13, 2007 06:26
Can Tecplot calculate isosurface area alon axis x? leaf Tecplot 0 May 21, 2007 12:20
how to export x- and y-axis of isosurface ? Tom CFX 6 May 31, 2006 13:19
Copying isosurface Giordano Bruno FLUENT 0 June 20, 2005 07:49
about rate of species creation and depletion shao FLUENT 1 July 8, 2002 15:21
