Turbulence
Old   October 23, 2009, 11:15
Default Turbulence
Andrej Hoyningen
darookie is on a distinguished road
Do you know any equation to determine the turbulence intensity, because I need initial values for the k epsilon model.
With the following equations i could calculate them regarding to the mixing model:
k= 2/3*(U_{ref} T_i)^2
\epsilon=C_\mu^{3/4} *\frac{k^{3/2}}{l}
Is this approach common or are there other proceedings?
Thanks for your replies
darookie is offline   Reply With Quote
Old   October 24, 2009, 05:54
Have a look in a turbulence modelling textbook. "Turbulence Modelling for CFD" by Wilcox is the one I use. That will explain the origins for a whole bunch of models.
Alternately have a look at either what you know about the turbulence field fro mthe experimental results OR have a look at the turbulence definitions available in CFX to see the other options.
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 07:22
Question on Turbulence Intensity Eric FLUENT 1 March 7, 2012 04:30
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 17:15
