Solver error
Old   November 9, 2009, 07:38
Default Solver error
ManChiu
jeff_F is on a distinguished road
I'm working on a spray simulation with liquid evaporation model. The simulation stopped in the partitioning stage and gave the following error message. Do you guys have any idea about this? Thanks for your help!
Jeff
Details of error:-
Error detected by routine MAKDAT
CDANAM = COUPLED_COMP CDTYPE = CHAR ISIZE = 20
CRESLT = OLD
Current Directory : /FLOW/PHYSICS/ZN1/PT1/MT4
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Stopped in routine MEMERR |
| An error has occurred in cfx5solve: |
| The ANSYS CFX partitioner exited with return code 1. |
This run of the ANSYS CFX Solver has finished.
jeff_F is offline   Reply With Quote
Old   November 10, 2009, 04:52
Looks like an error in the setup, probably in the particle tracking (I assume you are using this to track the droplets).
Old   November 10, 2009, 08:07
ManChiu
Thanks ghorrocks.
I agree with you. Do you have any idea about the directory "MT4"? Is the error related to the material properties of droplets?
Old   November 10, 2009, 16:50
stumpy is on a distinguished road
I would guess MT = Mass Transfer. Check the fluid-pair data between the fluids and the particles.
stumpy is offline   Reply With Quote
Old   November 10, 2009, 17:38
ManChiu
Thanks stumpy! I will check on that
Old   November 17, 2009, 03:10
mactech001 is on a distinguished road
Hi jeff,
just out of curiosity, is there a particular pressure/velocity value that indicates/defines that a liquid is spraying out from the nozzle and not dripping please?
look forward to hear from you.
Thank you for your kind attention.
Kind regards,
mactech001
Currently using: ANSYS v13
mactech001 is offline   Reply With Quote
Old   November 17, 2009, 05:19
ManChiu
It depends on what liquid you are using. The atomization process is related to Weber number. If you want to know more, you can read "Atomization and Sprays" by H. Lefebvre
Old   January 6, 2010, 00:38
Hello again Jeff,
i would like to try to perform a simulation to determine the required nozzle dimension so that i can achieve fluid jetting out at the outlet.
in the model, i am thinking of including the following parts:
1) nozzle geometry
2) air geometry
3) fluid geometry
boundary conditions:
1) inlet fluid mass flow rate
2) fluid outlet pressure is 0Pa relative to 1atm
3) but how do i deal with the interface between fluid and air please?
Look forward to hear of your comments on simulating jet/spray.
Kind regards,
mactech001
Old   January 7, 2010, 09:42
ManChiu
Are you working on VOF? I'm also exploring this field and not very familiar with it.
For the first trial, I may set it as a mixture first.
Old   January 9, 2010, 20:40
Hi Jeff,
what do you mean by VOF please?
Kind regards,
mactech001
Old   January 9, 2010, 23:09
ManChiu
Volume of Fluid
Error #001100279 bharath CFX 9 March 25, 2015 05:31
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 10:46
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
Problems about compiling a new solver fw407 OpenFOAM Bugs 0 December 23, 2007 17:03
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
