CFD problem, suggest
Old   November 27, 2009, 04:30
Default CFD problem, suggest
Ramandeep Singh
RAMAN6089 is on a distinguished road
i'm an HVAC Designer and a new user for CFD also.
i need ur experience while solving a fluid problem relating to air ducts.
i have designed one ducting Plenum(air box), i'm checking the feasibilty for the same.
conditions are:
Air is supplied to the ducting system by fan at 9.14 m/s (it's a big) to fulfill the capacity of 38000 Cfm(or 64600 m3/hr) each(there are two fans)
two inlets in plenum and two outlets from plenum
my conditions for Pre are:
Inlet:
normal speed = 9.14 m/s
at outlet i'm making it as opening and static pressure= 250 Pa or 25mmWc
i'm doubtful how this static pressure is gonna effect coz there is sepration in the ducting afterwards. and if i give velocity at opening than it will forcefully withdraws the air through it. suggest
RAMAN6089 is offline   Reply With Quote
Old   November 27, 2009, 04:53
Read the documentation about tips for obtaining convergence. Putting an outlet boundary through a recirculation zone is a bad idea. You should move it downstream to somewhere the flow is simpler.
Old   November 27, 2009, 04:59
Default hi
Ramandeep Singh
gharock,
i know about the wall condition which got created when we give the outlet condition.
i opted not to go further with downstream as the velocity is high, in place i took it as an opening.
suggest me about calculating the static pressure at the opening.
Old   November 27, 2009, 05:09
Read the documentation - if you put the boundary through a recirculation the static pressure (or any other variable for that matter) is not constant so defining a constant pressure boundary will lead to an error.
The speed of the flow is not important for setting a boundary location. If the flow is simpler with no recirculations then move it downstream as the error will be much reduced by a constant pressure boundary.
Old   November 27, 2009, 05:16
Default gharocks
Ramandeep Singh
gharocks,
it's not that, i'm not getting results. i have checked the flow is smooth at oulet, i have also given an opening condiyion for the same.
can u find me the particular example u have gone trhu, i'm finding it really difficult to get the perfect answer.
inlet and static pressure related
Seniors Pls suggest which Uni is best for CFD Sandeep Rana Main CFD Forum 2 June 13, 2007 13:29
Seniors Pls suggest which Uni is best for CFD Sandeep Rana Main CFD Forum 4 June 11, 2007 02:59
ill-posed CFD problem ? Noel Main CFD Forum 9 March 28, 2007 11:37
What is the Better Way to Do CFD? John C. Chien Main CFD Forum 54 April 23, 2001 08:10
part-time-cfd Michael Main CFD Forum 6 February 2, 2000 12:01
