Low Reynolds Number k-epsilon formulation CFX 10.0
Old   May 19, 2007, 11:06
Default Low Reynolds Number k-epsilon formulation CFX 10.0
Chris
Hi All,
I am trying to implement a Low Reynolds number turbulence k-epsilon formulation, in order to compare it to a solution obtained with the SST model, using CFX 10.0. However I can't find anywhere where I can choose a low Reynolds number k-epsilon formulation â€" only the standard k-epsilon is available.
When selecting the standard k-epsilon model it is possible under wall functions to change the y+ value that is set to 11.06 by default. By lowering the value can I then obtain a low Reynolds formulation? â€" Does anyone know what altering the value will mean?
Thanks in advance Regards Chris
Old   May 20, 2007, 16:52
Default Re: Low Reynolds Number k-epsilon formulation CFX
Gert-Jan
Do you have CFX-Flo?
Old   May 21, 2007, 05:22
Chris
I'm not sure but I don't think so. I'm running ANSYS CFX 10.0 I don't know if it is included.
Old   May 22, 2007, 03:32
Gert-Jan
You should know what you have. CFX-Flo is a starter package. What does your license file say? Can you perform a run and have Pre and Post opened simultaneously?
Gert-Jan
www.bunova.nl
Old   December 7, 2009, 23:51
Default Using CCL
Hyun-Min Kim
Kim-HM is on a distinguished road
CFX option not shown in GUI, it is able to use by CCL
Clik Edit in Command Editor then CCL window will open
you can see below
TURBULENT WALL FUNCTIONS:
Option = Scable
END
you can use low Re-model on every turbulent model by Scable -> Default
if you want other wall funtions option, search 'turbulent wall functions' on help in CFX
Kim-HM is offline   Reply With Quote
low reynolds number models in Fluent doug Main CFD Forum 6 August 4, 2012 14:39
Reynolds number in CFX tuks CFX 0 May 25, 2005 01:16
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
k-epsilon model, low Reynolds number formulation Märta-Karin CFX 1 September 15, 2003 21:37
Low Reynolds number K-Omega modeling Athar Zaidi Main CFD Forum 0 October 31, 1999 13:59
