Gas Turbine Vane- PS/SS Post-Proc
Old   December 17, 2009, 08:36
Default Gas Turbine Vane- PS/SS Post-Proc
puga is on a distinguished road
I'll start by saying that I'm not very adept at CFX, and am trying to post process a coworker's model of a gas turbine vane. I'm trying to extract data using the "Turbo" mode at a given span on the vane. This works great, except that it just lumps all the data around the airfoil together.
Is there a way to break this up into pressure(concave) and suction (convex) sides?
I'm using CFX 11.1.
Thanks in advance.
puga is offline   Reply With Quote
Old   December 20, 2009, 10:01
Abou ali is on a distinguished road
This is possible by using plot in a polyline. First create a Turbo Surface at mid span by using the command: Insert/Location/ Turbo Surface, then create a polyline by using the command: Insert/Location/ Polyline, in Method under the Details of Polyline table choose Boundary Intersection and select one side of the blade in Boundary List and the turbo surface in Intersect With. Finely you can plot the variations of any variable in this polyline.
Abou ali is offline   Reply With Quote
Old   December 21, 2009, 07:18
Awesome, I'll give that a try today. Thanks again.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
force acting on gas turbine blade.... vvj Main CFD Forum 1 March 3, 2010 01:04
Setting up gas turbine blade geometry for meshing sherifkadry Main CFD Forum 0 June 1, 2009 16:28
heat transfer from hot gas to cooled vane Chris Avenell Main CFD Forum 2 August 23, 2005 16:27
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
