joining two domains using boundary conditions
Old   February 2, 2010, 07:54
Post joining two domains using boundary conditions
Jake Mealy
mealyj is on a distinguished road
hi all,
is it possible to connect the outflow from one domain to the inflow of another domain in ansys? i have specified different fluids in each domain and i want one to flow into the other and mix. any ideas?
cheers.
mealyj is offline   Reply With Quote
Old   February 2, 2010, 16:28
You might be able to connect them using periodic boundary conditions.
Old   February 4, 2010, 02:12
Guohua Gao
gaoguohua is on a distinguished road
I think you just need the Domain Interface instead of any boundary condition.
gaoguohua is offline   Reply With Quote
Old   February 4, 2010, 05:00
Good point - it depends on what you are trying to do. Can you describe what you are trying to do with this inlet/outlet more? Can you post a picture?
Old   February 4, 2010, 11:09
Question
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
I think, if you are using interface for domains, you can use only one fluid type, or am I wrong?
Attesz is offline   Reply With Quote
Old   February 10, 2010, 10:31
Jake Mealy
Yeah, I was actually just making the problem more complicated than it needed to be. But a domain interface definitely works best I think.
Thanks for your help guys.
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
Problems with boundary conditions for a lowRekOmegaSST turbulence model cfdmarkus OpenFOAM Running, Solving & CFD 16 November 14, 2011 04:44
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
Pressure boundary conditions Lionel S. Main CFD Forum 1 August 24, 2007 18:03
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 18:29
