Velocity field problem
Old   February 15, 2010, 15:50
Question Velocity field problem
feizaghaee's Avatar
moein
feizaghaee is on a distinguished road
Send a message via Yahoo to feizaghaee
hi. i work with cfx 12 and i'm trying to simulate a free surface flow in a rectanular channel with ssg turbulance model. but there is something rong with the velocity field. i use homogeneous multiphase flow. the max velocity is about 0.9 y from bottom of channel. i attached a pic of velocity field. does anybody know how can i correct it?
feizaghaee is offline   Reply With Quote
Old   February 16, 2010, 00:48
feizaghaee's Avatar
moein
does anybody know what's the reason of this problem??????
Old   February 16, 2010, 03:04
zandi's Avatar
Fatema Zandi Goharrizi
zandi is on a distinguished road
salam
i couldn't undrestand what's problem. could you explain it more. is the place of the highest velocity point wrong or value of it. it changes from zero to max from boundary to near the surface, seems to be right.
zandi is offline   Reply With Quote
Old   February 16, 2010, 08:01
feizaghaee's Avatar
moein
it's not correct because the max velocity occures at .9 y (depth) from bottom of the channel
Old   February 16, 2010, 17:28
I assume you mean the problem is the max velocity does not occur at the free surface.
Have you done a mesh sensitivity study?
Old   February 17, 2010, 05:46
zandi's Avatar
if you mean the water surface and
if you have done mesh study just near the boundary or whole domain, did you ever note the water surface. about mesh adaption, did you ever test it for Air at 25 C.Volume Fraction ?
Old   February 18, 2010, 01:28
feizaghaee's Avatar
moein
no i mean the max velocity must occurs at the .7 hight of water from bottom of channel.
Old   February 18, 2010, 01:51
feizaghaee's Avatar
moein
the channel is toward the Z direction and i use hexa mesh. the hexa meshes have .2 m long in Z direction and in the XY plane have a shape like attached picture. the finer mesh is around the free surface. what do you think of mesh. is it too large
Old   February 18, 2010, 16:46
I must have said this a thousand times, but here goes again.
The only way to be sure your mesh is OK is by a mesh sensitivity check. Run increasingly fine meshes until the parameter of interest converges to a tolerance you can accept.
You cannot just look at a mesh and know whether it is fine enough without extensive experience in that field of modelling.
So that means that in this case, yes, almost certainly the mesh is too coarse.
Old   February 19, 2010, 03:52
feizaghaee's Avatar
moein
but i've checked with different size and the results was same. i've worked with .85 m long meshes but the result was exactly as same as meshes with .19 m long. the turbulence did'nt affect the results.
Old   February 20, 2010, 05:06
What makes the maximum velocity not occur at the top of the heavy fluid? Can you explain what you are modelling a bit?
Old   February 20, 2010, 12:47
feizaghaee's Avatar
moein
i'm modeling a channel with water and air flow. the secondary flows cause max velocity dosen't occur at top of the flow.
Old   February 20, 2010, 14:43
zandi's Avatar
how the secondonary flow force the max velocity in z direction occur in 0.7y not in near the surface?not sure but may be it is right for the y or x direction not for the main flow direction.
Old   February 21, 2010, 17:37
Where do the secondary flows come from? Is the channel curved?
Old   February 22, 2010, 03:01
feizaghaee's Avatar
moein
i finally understand the reason of this problem. the secondary flows in velocity field are exactly inverse (attached pic). does any body know what's the problem?
Old   February 22, 2010, 19:35
Is your simulation fully converged?
I assume the secondary flows are coming from the Reynolds Stresses in the RSM model. These are tricky things to get right, you may need to tweak some model constants - if you are brave.
Old   February 23, 2010, 04:05
zandi's Avatar
Originally Posted by feizaghaee View Post
i ....... the secondary flows in velocity field are exactly inverse....
fine
would you please explain it more
I want to learn actually
you mean that your problem was about velocity in x and y direction?
Old   February 23, 2010, 06:22
feizaghaee's Avatar
moein
yes, they are coming from Reynolds stresses.
what do you mean by "These are tricky things to get right, you may need to tweak some model constants" ?
Old   February 23, 2010, 16:42
I mean exactly that - secondary flows are tricky to get right. Are you sure RSM will adequately capture it? You may need an LES approach. I don't know, this is not my field.
Zandi - Google search "secondary flow". Wikipedia probably has a good description. That will explain what a secondary flow is.
Old   February 24, 2010, 03:59
feizaghaee's Avatar
moein
diffrerences between Reynolds stresses result in this scondary flows but CFX calculates these flows inversely i don't know why.
Problem Interface Solid Fluid with wall velocity Solver v12 hills1 CFX 2 October 12, 2009 05:36
Extract velocity field in certain time step to MATLAB spatialtime CFX 3 September 9, 2009 18:30
Convergence problem with thermal phase change model under low velocity conditions pitisrisuk CFX 0 July 21, 2009 11:21
Streamline superimposed on velocity field allamarein FLUENT 0 July 9, 2009 20:51
velocity problem phy FLUENT 1 February 8, 2008 17:12
