How to force hp-mpi a certain IP
Old   March 5, 2010, 11:47
Default How to force hp-mpi a certain IP
grand master
grandmasterm is on a distinguished road
Hello everbody
Sometimes my connection gets lost and hp-mpi sets the ip to 127.0.0.1 and looses remote lic server. Is there a possibility to force with the cfxsolve command to connect to an solid IP? i know the rule with mpirun -netaddr but i dont get it with CFXSOLVE. Anyone has the same problem and can help?
Greetz,
GrandM
grandmasterm is offline   Reply With Quote
Old   March 6, 2010, 04:47
Easy - rather than referring to the machine by its machine name give it the IP address. It should work fine.
Old   March 6, 2010, 05:53
grand master
can you give me an example with 4 partitions?
like
cfxsolve -def bla.def- startmethod "mpichloc....parallel" - part 4 -netaddresorsso?!?
i tried many commands but all do not seem to work. I simply dont know where to the ip. And i dont know neither if i can put it somewhere in the cfx pre GUI.
Old   March 6, 2010, 06:09
No, you will have to define the machines as IP addresses in the hosts.ccl file in <CFX ROOT>/config directory. (I think that's right, I am doing this from memory)
Old   March 11, 2010, 10:17
grand master
hello! I think you mean the hostinfo.ccl ?
SIMULATION CONTROL:
EXECUTION CONTROL:
PARALLEL HOST LIBRARY:
HOST DEFINITION: ********
Remote Host Name = +++++++++
Installation Root = C:\Program Files\ANSYS Inc\v%v\CFX
Host Architecture String = winnt
END # HOST DEFINITION ******
END # PARALLEL HOST LIBRARY
END # EXECUTION CONTROL
END # SIMULATION CONTROL
when i change host definition or remote host name to an ip instead of hostname its still not using the defined ip.
or do i have to change it somewhere else?
the mpirun option is -netaddr , so maybe i can add this line somewhere in the cfxsolve routine?
this cannot be so hard, to point the hp-mpi to a certain ip, can it?
greetz
Urgently Need the code of Lift force and VM force Kai Yan Main CFD Forum 0 July 16, 2008 07:07
Error using LaunderGibsonRSTM on SGI ALTIX 4700 jaswi OpenFOAM 2 April 29, 2008 10:54
Is Testsuite on the way or not lakeat OpenFOAM Installation 6 April 28, 2008 11:12
DEFINE_CG_MOTION and pressure force Teo Fumagalli FLUENT 0 April 11, 2008 10:25
pressure force and viscous force CFD FLUENT 0 March 7, 2006 01:03
