How to insert points to DesignModeler of Ansys?
Like Tree3Likes
Old   April 10, 2014, 12:57
Ashutosh
dreamz is on a distinguished road
@shubham jain:
I came to know where was my mistake. I was trying to create surface from sketches. I thought the 3D curve as a sketch. I tried surface from edge and got the proper surface. I could also create the domain around it after boolean subtraction. As far as my problem is concerned, its solved.
But, what intrigues me is, when I import my co-ordinates after adding that 1 0 line I get sort of distorted tail of the airfoil. Please see the attached image.
While with your co-ordinates I could get a perfect one. I saw that you have specifed the last y-cordinate specified by you is the same one as the first one. Only it is negative. I also find the 1 0 line missing. Can you point the logic behind it.
Also, it will be very nice if you could tell how you generated so many number of points for the naca0015 profile. Is their a website or software?
dreamz is offline   Reply With Quote
Old   April 10, 2014, 15:32
Red face
  #22
shubham jain
shubham jain is on a distinguished road
i think the distortion is due to less number of points.
it creates the curve using spline.. (i guess)..so spline with less number of points can make a mess
regarding 1 0 line...
as far as i know.. 1 0 line is for closing the curve.. so make i dont know how did u create a closed curve without 1 0 line in .txt file. Did u make some changes in your file. How did u make closed curve???
u can use these online generators.. i prefer these
http://www.ppart.de/aerodynamics/profiles/NACA4.html
http://airfoiltools.com/airfoil/naca4digit
apart form these,...there must b many more available online
shubham jain is offline   Reply With Quote
Old   April 10, 2014, 18:17
NACA shapes are defined by an equation. Here is a reference to the equations: http://en.wikipedia.org/wiki/NACA_airfoil
If you use the underlying equation you can generate continuous curves and do not have to rely on gizmos which generate points.
The distorted point at the end is it trying to make the sharp cusp at the end a continuous curve. It is not a continuous curve, so it have to do a weird distortion to make it continuous. You need to make sure the cusp point is kept as a cusp and not made continuous.
dreamz likes this.
Old   April 11, 2014, 02:01
shubham jain
@ghorrocks
Can we generate airfoil as a continuous curve (instead using points) using the equation of airfoils in ICEM CFD??
or may be in Design modeler also??
thanks in advance
Old   April 11, 2014, 03:11
I am no expert in ICEM, I do not know if you can put in equations. I am pretty sure you cannot in DesignModeller. You probably need a high-end solid modelling package like unigraphics/ProE/Solidworks.
But you can use the equations to generate as many points as you think you need to accurately model the geometry. You also have the choice of using a few less points and a curved fit with splines, or more points and linear line segments. The linear segments are attractive as you do not need to worry about tangency issues, so the funny blob at the end of your last image will not occur.
Old   April 11, 2014, 03:34
shubham jain
thanks for quick replies..
I have used CATIA. can you guide me how to create airfoils using equations in CATIA
I have created airfoil using points (by importing points from excel file in catia) but i don't know if there is option to generate curve using equations in catia also??
Old   April 11, 2014, 05:58
That sounds like a question for a catia forum like
http://www.3dcadforums.com/catia-forum/
or
http://www.eng-tips.com/threadminder.cfm?pid=560
Old   April 12, 2014, 12:15
Ashutosh
@shubham:
I had added the 1 0 line at the end of the file. The explanation by ghorrocks seems satisfying to me.
Old   March 10, 2015, 11:55
Default to import airfoil geometry
  #29
Gujarat
hardik47 is on a distinguished road
I could'nt import geometry , i ve tried igs,stp and prt file but it could'nt br generated.
hardik47 is offline   Reply With Quote
Old   March 10, 2015, 12:03
Gujarat
Error: No compatible interface found for this file type
Context: Attach Feature Import1
Error: Geometry Interface not found.
Error: Attach failed.
Old   November 16, 2015, 09:24
re
rere is on a distinguished road
Originally Posted by shubham jain View Post
first of all.. try to get more points..they are just 35 points.
try to get atleast 100 points from some online airfoil generator.
second, yes, u need to put 1 0 in last point, to make a closed curve.
try this attached file and check what is the difference in your file and mine, and let me know!!!
Hi Shubnam,
I noticed you've helped with ansys airfoil coordinates and was hoping you'd be able to shed some light on where I'm going wrong, please?
Ansys Error message:
' Error reading Coordinates File '
please find attached the coordinates file and the following link with the source for the coordinates: http://wind.nrel.gov/airfoils/shapes/S814_Shape.html
thanks
rere is offline   Reply With Quote
Old   November 16, 2015, 11:11
dB
darkBLACK is on a distinguished road
Originally Posted by rere View Post
Hi Shubnam,
thanks
for last point, put
group point
1 0
thats all.
S814Airfoil_.txt
darkBLACK is offline   Reply With Quote
Old   November 16, 2015, 12:14
re
Originally Posted by darkBLACK View Post
for last point, put
group point
1 0
thats all.
Attachment 43512
I tried that method previously and It didn't work, neither did it work from your file
this was the error message:
Error: Invalid Group/ID found in coordinates file
Context: POINT FEATURE POINT1
Line: 67
p.s: I've been working on solving this problem all day :/
Old   December 5, 2015, 00:48
Default Help...
  #34
NITW
digvijay19921 is on a distinguished road
Can anybody tell me..I want to import some data point of 3 different group...I've made in .txt file....But while uploading these point I got message of ......error to read it.......Is there anyone else phase this problem....Please help me How can tackle these situation.....Thanks in advance...May I know that is there any specific order of input point or it may be random.....
digvijay19921 is offline   Reply With Quote
Old   August 4, 2016, 12:06
Negar Saeidi
nsaeidi is on a distinguished road
I am writing under an old post! I hope somebody get back to me on this:
I am trying to create points in Geometry from Coordinate File which is attached. When I generate, a yellow tick shows up next to Points ( rather than Green) but I can see the points in the model view.
In addition, I can not make line from those points. Also, when I want to make 3D Curves from the same coordinates file I receive Error reading coordinates file.
Can anybody tell me what is the problem?
nsaeidi is offline   Reply With Quote
Old   August 4, 2016, 15:20
Negar Saeidi
I found the answer!
The reason is that my coordinates are beyond +500 and -500 meters
Old   August 23, 2016, 09:19
Harry Eggo
harry94 is on a distinguished road
Hi guys, just stumbled across this thread so will revive it for my problem.
I'm trying to import a large number of points and need a way to connect them all together and bound them by the z axis. It is elevation data that I am trying to import.
I have processed it on MATLAB and applied what has been discussed earlier to keep it between -500 and 500 for the x and y axis. I can't import my data in one as it exceeds 10000 but I've split it into different files. I find that I can import the files easily when clicking Create - Point - Create Coordinates file but when trying to create a 3D Curve (Concept - 3D Curve), I return the error message that declares that it can't read the file.
I have also tried to close the curve too which hasn't help.
I believe that this may be due to the points possibly intersecting with themselves but that is necessary in regards to what I need to do. Does anyone have a method that would allow me to connect all these points together?
Attached an example file.
harry94 is offline   Reply With Quote
Old   August 23, 2016, 10:30
Negar Saeidi
Dear Harry,
I had the same problem as you. They only way I could sort it out was that I ordered my points based on their elevation and saved them in individual text files. Then I imported them individually and made the 3D curve manually. It was a lot of effort, but I couldn't find another way.
Hope it helps.
Also, make sure that the format you are using in your text file is correct!
Old   August 23, 2016, 10:35
Harry Eggo
Originally Posted by nsaeidi View Post
Dear Harry,
Hope it helps.
Thanks for your response. Yeah that seems to be the road I'm having to go down right now. Going to try and script it as much as possible as think I'll need to do this regularly.
Old   October 21, 2016, 14:24
Default 3d curve
  #40
Nidhi Nara
Nidhi Nara is on a distinguished road
hii,
im having issues to import the coordinates file for 3d curve.
i tried putting commas as well but that didnt helped.
here is my coordinates file.
any suggestions?
Nidhi Nara is offline   Reply With Quote
ANSYS DesignModeler Ema ANSYS Meshing & Geometry 3 November 3, 2009 03:37
Insert of commands from classic in ansys in ansys w.b. sirijo ANSYS 1 October 24, 2009 10:09
ansys DesignModeler importing NAca realanony87 ANSYS Meshing & Geometry 0 May 28, 2009 16:29
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 01:10
