Post-Processing with Symmetry
Like Tree7Likes
Old   March 3, 2010, 11:32
Default Post-Processing with Symmetry
Jade M is on a distinguished road
How do you plot results for the full domain if symmetry was utilized in the analysis? Thanks so much for any information!
Jade M is offline   Reply With Quote
Old   March 3, 2010, 18:02
Use a transformation to get it to mirror at the symmetry plane. Some of the CFX tutorials do this, have a look there.
Old   June 21, 2010, 10:40
For those who are interested, I found a tutorial on ANSYS' site showing the steps using the Reflect/Mirror tool. With CFD-Post loaded, click File > Load State and select the .cst file. Right click in the graphics menu, and click Reflect/Mirror. Post asks "Which direction do you want the normal in?" Click the axis desired for mirroring the geometry. The .cst file should be located in the file structure dp0\CFX\Post. If the project involves multiple design points or cases, then go to the respective folders for the appropriate design point (dp1, or dp2, etc.) or for the appropriate case (CFX-1 or CFX-2, etc.).
alinik, Stabum and rajann_786 like this.
Old   January 13, 2016, 18:38
anonymous
Doginal is on a distinguished road
Hey All
Sorry to bring up an old dead topic. But I created a reflect/mirror using the right click method listed here. Now I cannot seem to figure out how to get rid of it. I try using the same method (right click on wireframe and see option for mirror/reflect) however it only seems to be an option to create it, not remove it onces its already made.
Anyone know how to remove a mirror/reflect once already made?
Doginal is offline   Reply With Quote
Old   January 14, 2016, 01:48
Every object will have a transformation option as part of its settings. You can remove the mirror transforms by removing the transformation option in each object.
Old   January 14, 2016, 12:13
anonymous
Thanks for the reply
Before reading this while trying to take screen grabs I actually noticed that there is the "default transform" option under the "user locations and plots" heading in the Outline tree. I managed to change that to match another case which removed my mirror. This one had stumped me for a while causing me quite the headache.
Note to developers, when you have a right click option to turn something on......keep it there to turn things off as well. It also doesn't help when the solution in the help documents is to push undo twice.
Old   June 24, 2016, 01:28
upender singh
upender is on a distinguished road
Hi, my model is axi-symmetric. What is the procedure to generate the complete geometry for visualization in this case?
upender is offline   Reply With Quote
Old   June 24, 2016, 10:25
Opaque will become famous soon enough
Double click on the axisymmetric domain, and look at Instancing. You can make as many copies as you need to form the full circle
Zari and upender like this.
Opaque is offline   Reply With Quote
Old   June 24, 2016, 19:04
upender singh
Hi opaque,
thanks for the reply. I tried increasing the instances beforehand but too many of them overload my computer. I was wondering, if in any way I could increase the angle of the 3D wedge that shows up in the graphic window by default.
Update: I have used a axis-symmetry condition in the mesh modeller. I can see that the mesh can be viewed in 3D. In static structural module, using such type of condition reflects in post-processing sessions. Is there a way to do the same for fluent and cfd post sessions?
Regards
Old   January 12, 2017, 10:59
Zari Musavi
Zari is on a distinguished road
I am also looking for such a solution, to create 3D graphics from a 2D axi-symmetric model in Fluent 17.2.
would appreciate if you or other CFDiers could suggest solutions.
/Zari
Zari is offline   Reply With Quote
Old   January 12, 2017, 16:30
This is the CFX forum. Try the fluent forum for Fluent issues. But I presume you are using CFD-Post which is the post processor for Fluent and CFX. You can set this by changing the default transform options. Have a look in the CFD-Post tutorials for examples of how to do this.
Zari likes this.
Old   January 16, 2017, 05:49
Bruno
brunoc is on a distinguished road
When you load a 2D case from Fluent in Post, it is "extended" to 3D: planar 2D gets extruded, axy-symmetric 2D becomes a wedge.
With that in mind, just use the instancing method described above by Opaque.
Zari likes this.
brunoc is offline   Reply With Quote
Old   May 24, 2018, 13:12
sandy
archeoptyrx is on a distinguished road
Is there a way or workaround to export results for a 360 deg model from this symmetry model ?
Thanks
Sud
archeoptyrx is offline   Reply With Quote
Old   May 24, 2018, 13:48
Erik
evcelica is on a distinguished road
For 360 deg, just use an instance transform with a rotation, instead of a reflection.
For example, if you did 1 degree simulation, make 360 copies, and do rotation of 1 deg about your center axis.
If you modeled 2 deg, do 180 copies, and rotate 2 deg.
evcelica is offline   Reply With Quote
Old   May 24, 2018, 17:07
sandy
Hi Eric,
I wanted to export that 360 deg data into an excel file. Is that possible ?
Thanks
Sandy
Old   May 25, 2018, 02:51
Gert-Jan
Gert-Jan will become famous soon enough
I suggest to do the rotation in Excel. Should nopt be too difiicult..............
Gert-Jan is offline   Reply With Quote
Old   June 16, 2018, 09:30
Default need your hlep
  #17
leo
jinsong is on a distinguished road
i do a simulation with fluent 2D axi-symmetric model,i want looking 3D graphics by post processing,how can i do it in CFD-POST???
/Zari
jinsong is offline   Reply With Quote
Old   June 17, 2018, 07:07
Use an Instance Transform (tutorial: https://sharcnet.ca/Software/Ansys/1.../i1313639.html)
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   June 17, 2018, 08:10
leo
thank u for your reply,i just try it .
i think it is firstly create a reflection plane,then ,create a instance transform,last i can apply the new transform to graphics objects.
but the result is bad,it is still a 2d geometry , jsut 2d symmetric geometry,not 3d ,how can i do it? thank u again
leo
post processing for KIVA dirga Main CFD Forum 5 April 23, 2009 10:58
Question about post processing qtian OpenFOAM Post-Processing 0 July 24, 2007 12:44
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 11:59
Urgent help needed in post!!. processing results.. Deadly FLUENT 0 August 21, 2002 00:42
post processing in CFD MANISH BHARGAVA Main CFD Forum 0 October 17, 1998 20:51
