for help about cfx boundary condition settting
Old   July 3, 2011, 09:11
Smile for help about cfx boundary condition settting
tao
rainning139 is on a distinguished road
Dear all,
I want to simulate the gas flow in a pipe using cfx ,gas at the inlet positon is
15000Pa(Guage pressure),velocity is 3m/s and i mean to know the outlet preesure.As a new learner ,I need your help now.I'm puzzled how to set the boundary conditons.Please give me the answer if you knows.Thanks a lot.
rainning139 is offline   Reply With Quote
Old   July 3, 2011, 19:05
You have overspecified the inlet. You cannot define both velocity and pressure at an inlet.
I would convert the velocity to a flow rate, and apply the flow rate to the outlet. Then you can use 15kPa at the inlet and a mass/volume flow rate outlet boundary.
Old   July 3, 2011, 21:26
tao
\Thank you for your answer.i will have a try .however I still have a question.NOW I want to use 2D model and the diameter of the pipe decreased in the middle, just like a Venturi tube.I guess the velocity at the outlet may be different from the velocity of the inlet,because the pressure change at the outlet,then the volumne flow rate will change.
I have used 15kPa at the inlet and the total mass flow rate of the 3D whole pipe as the mass flow rate of the 2D model,then I found the velocity is big abnormally,about 2900m/s. IS the mass flow rate improper?
HOPE for your answer.THANKS AGAIN!
Old   July 4, 2011, 06:25
If you are taking a 2D slice for a model then you need to reduce the flow rate according to your sector angle.
Old   July 4, 2011, 20:45
tao
THANKS.I will have a try
boundary conditions, cfx 12.1
CFX problems with supersonic inlet condition - Inlet values in CFX-Post are wrong jannnesss CFX 5 February 25, 2011 16:24
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
CFX mass flow boundary condition Michele Cagna CFX 3 February 22, 2007 15:52
Pressure Boundary Condition Matt Umbel Main CFD Forum 0 January 11, 2002 10:06
The Boundary Condition about the Flat Plate boing Main CFD Forum 1 January 6, 2002 16:53
