June 2, 2010, 09:46 |
about function calculator
Rep Power: 15 |
The AoA is 12 degree,velocity is 10m/s
function calculator.jpg the X component force of the wing finally increases the Lift force and decreases the Drag force |
June 2, 2010, 18:35 |
Rep Power: 143 |
And your question is......
June 4, 2010, 02:01 |
Rep Power: 15 |
the result (-2.08692N)of the X component was right or wrong?
June 4, 2010, 08:21 |
Rep Power: 143 |
Are you asking if the force in the X direction is -2N - sounds wrong to me as the drag should be in the + direction, but I have no idea what you are modelling so cannot be sure.
June 6, 2010, 03:46 |
Rep Power: 15 |
I simulated a three-dimensional flow around the wing, angle of attack from 0 degrees to completely stall.
June 6, 2010, 06:23 |
Rep Power: 143 |
If you are running steady state then you have not run it to convergence. If you are running transient and you are near stall it is quite possible the airfoil will have short periods of negative drag. Averaged over time the drag will be positive.
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
