June 15, 2010, 12:42 |
Boundaries explanation
Rep Power: 15 |
Hello to everybody here.
This is my first post here and this is going to be a very easy question for all of you CFD experts. I am trying to analyse a competition car rear wing on Ansys CFX. I have designed the wing in CAD software. Then i must find a way to model a main boundary around this wing to model the air around of it. Not knowing exactly how this is done in CFX, i also designed a large cube in CAD, i put the rear wing inside this large cube and then by means of "Boolean operations" i remove the volume of the wing out of the cube's volume. So i can make a decent analysis. But i assume that there is some feature in CFX in which this is done automatically. The problem now is that i cannot take the walls of the rear wing and everytime the outer boundary (wall) is visible, confusing the things. I hope you can help me. Thanks! |
Setting Flow/Pressure Boundaries in Floworks | Eran | FloEFD, FloWorks & FloTHERM | 3 | August 11, 2009 04:23 |
periodic boundaries - flow through a net | PK | FLUENT | 0 | July 12, 2007 11:58 |
Periodic Boundaries in GAMBIT!! | swetha | FLUENT | 1 | November 26, 2006 22:02 |
problems replacing old boundaries | Jared | Siemens | 4 | August 5, 2005 19:36 |
mass flux correction at outflow boundaries | Subhra Datta | Main CFD Forum | 2 | November 24, 2003 13:11 |
