Parallel Processing ocean wave multiphase model
Old   July 26, 2010, 11:39
Default Parallel Processing ocean wave multiphase model
Rob Stringer
robb is on a distinguished road
Dear All,
I have successfully produced free surface waves using a multiphase setup in both 2D and 3D using CFX 11. The models have very conservate parameters and run fine on 1 processor, but as soon as i submit the same model in parallel it fails. The out file shows successful partitioning, and implimentation of MPICH communication on the cluster. I have tried standard MeTiS partitioning and coupled (-part-coupled on linux script). I was wondering if there were any tips for this such as partition weighting or partition algorithym that anyone has for multiphase parallel solving?
At the moment the models run using a single processor, but as soon as i attempt to parallel solve the same model, it fails on the first few iterations, any idea what i am missing?
Thanks!
rob
robb is offline   Reply With Quote
Old   July 26, 2010, 14:37
stumpy is on a distinguished road
Check that your partition boundaries do not line up with the free surface. If you write out a backup/res file after 1 timestep, then plot isosurfaces of partition number in Post. If they do line up, then try a user specified direction partitioning option.
stumpy is offline   Reply With Quote
Ocean Wave with Fluent? gholamghar FLUENT 3 June 16, 2015 05:51
free sw to model ocean wave energy device? Allen Main CFD Forum 0 August 31, 2009 16:59
solving ocean wave with Fluent or CFX? gholamghar Main CFD Forum 1 March 21, 2009 12:49
OpenFOAM 13 AMD quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 1 November 10, 2007 23:23
Ocean Wave Model with FLOW3D Haryo Armono Main CFD Forum 0 January 28, 1999 13:11
