How can define different diffusion coefficients |
April 21, 2010, 09:24 |
Frank Weise
Rep Power: 17 |
i will solve a fluidsystem (Water) with an porous domain. To simulate Oxygen transport in this system i use an Additional Variable. My problem is i can't define different diffusion coefficients in different domains. If i change in one domain the diffusion coeff. than is this cofficient in the other domain the same. What do i wrong or is't such possible. best regards Frank |
July 31, 2010, 09:43 |
catherina
Rep Power: 17 |
Don't know if you solved your problem yet there is a way of disabling constant physics in domains, actually there are a couple of threads describing how
http://www.cfd-online.com/Forums/cfx...s-cfx-pre.html http://www.cfd-online.com/Forums/cfx...nt-domain.html However, when I used this method the solver was very unstable and did not get accurate solutions. Depending on the problem you are trying to model, you might be better off by assigning different fluids, values to different domains setting user parameters for instance domain 1 = domain1 domain 2 = domain2 fluid name1 = Water fluid name2 = Vapor but have not tried that myself i only used user parameters in single flow simulation I will be going back to multiphase domains later this year (beginning of November to be exact) and will discuss it in length with my support. If by then you haven't sort it things out you are more than welcome to email me and I will give you further details. |
diffusion coefficient |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Installing OF 1.6 on Mac OS X | gschaider | OpenFOAM Installation | 129 | June 19, 2010 09:23 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 11:48 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
UDF FOR UNSTEADY TIME STEP | mayur | FLUENT | 3 | August 9, 2006 10:19 |
