Error within a batch run
Old   January 2, 2008, 22:46
Default Error within a batch run
Jia Li
Hi, guys!
I write a batch run file as followed. Where the ccl files varies only from the TM.
__________________________________________________ _________
cfx5solve -batch -def *.def -part 2 -start-method "MPICH Local Parallel for Windows" -bg-ccl epsilon.ccl -name epsilon
cfx5solve -batch -def *.def -part 2 -start-method "MPICH Local Parallel for Windows" -bg-ccl omega.ccl -name omega
The first run goes on well and get a good result. But the second one was interrupted by the following error. I don't understand the meaning of "signal HUP(1)". Please help me.
Jia
Error detected by routine MAKDAT CDANAM = ICTYPE CDTYPE = CHAR ISIZE = 12 CRESLT = OLD
Current Directory : /FLOW/INITCON/ZN1/VARIABLES/TED_FL1 STOP called from routine MEMERR +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | C:\Program Files\Ansys Inc\v110\CFX\bin\winnt\cclsetup.exe was | | interrupted by signal HUP (1) | +--------------------------------------------------------------------+
Old   January 3, 2008, 04:55
Default Re: Error within a batch run
Andreas
INITCON is for initial conditions ZN1 means first domain (but not necessarily in your order) TED_FL1 means Turbulence Eddy Dissipation for first Fluid
So there is a problem with the initialisation of turbulence eddy dissipation in one of your domains.
MAKDAT means the solver wants to MAKe a DATa area with name ICTYPE and type CHARacter with length 12, but found that this was already there (CRESLT=OLD).
So check your CCL for double entries regarding the initialisation of turbulence eddy dissipation.
Good luck!
Old   January 3, 2008, 07:40
Jia
Hi,Andreas!
Thanks very much! Your explain is exactly and in time. At the same time, I read the help on subroutine MAKDAT. It also helps a lot.
However, I have change the initialisation of TED in ccl file as attached. The error still emerged.
By the way, if running by GUI model with the exactly same settings, the error has never happened. Do you have further suggestions? Thanks!
Jia
INITIALISATION:
Option = Automatic
INITIAL CONDITIONS:
Velocity Type = Cartesian
CARTESIAN VELOCITY COMPONENTS:
Option = Automatic with Value
U = 20 [m s^-1]
V = 0.2 [m s^-1]
W = 0 [m s^-1]
END
K:
k = 0.0004 [m^2 s^-2]
END
OMEGA:
Eddy Length Scale = 18 [mm]
Epsilon = 0.0004 [m^2 s^-3]
END
STATIC PRESSURE:
Relative Pressure = 1 [atm]
END
TEMPERATURE:
Temperature = 310 [K]
END
END END
Old   January 4, 2008, 10:27
Andreas
Are you sure you wanted to use -bg-ccl and not -ccl, i.e. using your ccl as default and not as override? You should check the out file whether there are initialisation entries that are contradicting. Not the whole INITIALISATION singleton is replaced so that entries from the def file will be also there and this may cause problems.
Old   July 28, 2010, 14:14
Saima
Saima is an unknown quantity at this point
Hi ,
I am doing CFX in bact mode by using command:
C:\Users\sanaz\Desktop>"C:\Program Files\ANSYS Inc\v121\CFX\bin\cfx5pre.exe" -batch ROTOR.pre -icem project.msh
and i am getting error:
- Unable to read the "Length Units" from the "SOLVER UNITS" object.
Kindly let me know how can i avoid it. I dont understand about it.
Regards,
Saima is offline   Reply With Quote
Old   July 28, 2010, 21:17
Exactly what it says - there is an error in setting the length units. Have a look at the batch file script.
Old   July 29, 2010, 14:15
Saima
Yes, you are right, i solved it.
But now i got error in runing def file.
I am using command:
C:\Users\sanaz\Desktop>"C:\Program Files\ANSYS Inc\v121\CFX\bin\cfx5solve" -def Rotor_67.def
It produce my result file but it also give the messgae:
"Feature CFX_SOLVER_BASIC_MP_LIMIT does not exist in the ANSYSLI pool."
Acutally i mam using batch mode in iSIGHT optimization software this software stop after getting this messgae it takes as an error.
Old   July 29, 2010, 18:54
That is a licensing problem. Check you have the necessary licenses to run your model.
use batch mode to run an unsteady case PaulineP FLUENT 9 April 4, 2019 08:18
how to create input file to run fluent in batch Aireen FLUENT 6 November 21, 2016 08:27
batch run N.R. CFX 1 June 17, 2007 22:44
problem with running UDF in batch mode James FLUENT 0 June 6, 2006 06:49
Batch Run Ogbeni CFX 4 October 15, 2003 12:33
