June 17, 2010, 06:32 |
Non-Uniform Flux
sendhil
Rep Power: 15 |
Dear CFX user,
Do anyone know, how to give non-uniform boundary conditions (say heat flux) in a plane surface of a 3D objects? in ANSYS CFX My heat flux value is not uniform, so i want to give this value like this. Maximum at the center and minimum at the edges (NORMAL DISTRIBUTION). Can ANYONE give idea for my problem. Regards, SENcfx |
June 17, 2010, 08:15 |
Rep Power: 143 |
This is easily done with a CEL expression. This can be an analytical function or a 1D/3D interpolation function.
August 18, 2010, 18:04 |
Hai Ghorrocks,
sendhil
Rep Power: 15 |
Very recently i got this error dispalyed; Do you have any idea regarding this.
ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | SYMASS_CS_ELIM : The solver ran out of temporary space while buil- | | ding a linked list for a domain. Try setting the expert paramete- | | r "topology estimate factor" to a value greater than 1.0. Values | | higher than 1.2 should not be necessary. IT IS SOLID FLUID PROBLEM. please let me what is error? Regards, SENCFX. |
August 18, 2010, 18:49 |
Rep Power: 143 |
The problem is probably associated with a complicated GGI linking the solid and fluid domains. Check your interface mesh is well resolved and of good quality.
August 19, 2010, 06:22 |
sendhil
Rep Power: 15 |
ansys11 cfx |
boundary conditions for simpleFoam calculation | foam_noob | OpenFOAM Running, Solving & CFD | 8 | July 1, 2015 08:07 |
Pressure instability with rhoSimpleFoam | daniel_mills | OpenFOAM Running, Solving & CFD | 44 | February 17, 2011 17:08 |
rhoSimpleFoam | claco | OpenFOAM | 7 | April 20, 2010 04:32 |
buoyantSimpleRadiationFoam | msarkar | OpenFOAM | 0 | February 15, 2010 06:22 |
RasInterFoam STRANGE RESULTS AT BOUNDARY | kumar2 | OpenFOAM Running, Solving & CFD | 8 | March 24, 2008 18:38 |
