ERROR #001100279 in subroutine ErrAction
Old   August 16, 2010, 06:14
Default ERROR #001100279 in subroutine ErrAction
M. A.
motahar is on a distinguished road
Hi friends,
I'm simulating the pressure vessel of a pressurized water reactor.
I'm in transient state. In CFX-Pre, in output control, it is defined to write "backup" and "TrnResults" files for the "velocity", "temperature" & "pressure". ANSYS writes the "TrnResults" file for velocity, but for temperature & pressure after each timestep I encounter this error:
ERROR #001100279 has occured in subroutine ErrAction.
Write_res: Failed to rename 0.bak
Write_res: Failed to rename 0.trn
Can any body help me to solve this problem???
Need your help urgently!!!
motahar is offline   Reply With Quote
Old   August 16, 2010, 09:06
Matthias Voß
mvoss is on a distinguished road
hi,
try to set the compression to "standard".
neewbie
mvoss is offline   Reply With Quote
Old   August 18, 2010, 08:24
M. A.
Hi neewbie,
Thanks for your seggestion.
I set the compression to "standard", but again I received the same error.
It seems that it's impossible to default "backup" & "TrnResults" files for more than one variable simultaneously.
I appreciate any more help from friend!!!
Old   August 18, 2010, 08:33
Matthias Voß
hi,
create one result at a time containing u,p,T not one for each. i think that´s the problem when dealing with trn´s.
just pic the selected variables option and choose u,p,T (holding ctrl+).
neewbie
Old   August 20, 2010, 06:16
cfdgremlin is on a distinguished road
It's a bug in CFX 12.0 which is fixed (I believe) in CFX 12.1.
cfdgremlin is offline   Reply With Quote
Old   August 20, 2010, 12:46
M. A.
Hi, neewbie
Thanks a lot for your help.
I obeyed your suggestion. It worked successfully!!!
And an experience I would like to mention here so that it may be helpful for friends is that in making "backup" file, it's necessary to use "standard" option, otherwise if you use "select variable", when runnig backup file you cannot have the previous timestep results.
Again THANK YOU!!!
Old   August 20, 2010, 12:52
M. A.
Hi cfdgremlin,
Yes you're write.
That's a big bug in CFX 12.0.
Fortunately here in cfd-online forum we can help each other to solve these bugs.
ERROR #001100279 in subroutine ErrAction Stephan CFX 18 October 14, 2019 17:15
ERROR #001100279 has occurred in subroutine ErrAction. REDHDR:locating dataset failed Andy QUB CFX 3 September 30, 2019 01:44
Fortran Subroutine Error sergiorbrett CFX 12 September 3, 2012 07:40
ERROR #001100279 has occurred in subroutine ErrAction alinik Main CFD Forum 0 July 3, 2010 08:11
ERROR #001100279 has occurred in subroutine ErrAction. P9408 CFX 1 August 19, 2009 07:56
