ERROR #001100279 for a Rotating Fluid Domain
Old   May 20, 2008, 06:52
Default ERROR #001100279 for a Rotating Fluid Domain
Fonzie
I am using CFX 11.0 and have the folowing problem with the solver. It will crash during the second iteration step and give the following error messages:
ERROR #001100279 has occurred in subroutine ErrAction. Message: Could not invert control surface Ap
ERROR #001100279 has occurred in subroutine ErrAction. Message: Stopped in routine ASS_GLOBCS_IAP
I am investigating a channel flow on the segment of a rotating disc. Hence I have set the Fluid domain on rotating about one global axis. Correspondingly I have set all boundaries as rotating, as well. I should add that I am investigating a heat tranfser problem, so I also have interfaces to my solid domain.
The error messages will not occur when the fluid domain is set on stationary. However for my problem that makes no sense physically.
I appreciate every hint on this type of problem.
Regards, Andy
Old   June 10, 2008, 04:30
Default Re: ERROR #001100279 for a Rotating Fluid Domain
otrebla
I have the same problem but nobody answered to me
Old   August 24, 2010, 08:35
Arevik is on a distinguished road
I guess my answer is too late for both of you, but maybe it'll help somebody else one day
I've had the same problem. In my case it helped to restart the simulation with a much smaller (factor 50) timestep. Then I increased it step by step to the value I wanted. My case was a transient simulation of air between 2 concentric cylinders, where one of them was rotating (Taylor-Couette-Flow).
Arevik is offline   Reply With Quote
Old   August 24, 2010, 19:42
Joshua Counsil
Josh is on a distinguished road
Thanks, Arevik. I'm always upset when people figure out their problem but don't update the threads.
Josh is offline   Reply With Quote
multiple fluid domain Sumedh CFX 10 December 14, 2016 16:36
CFX domain comparison Kiat110616 CFX 4 April 3, 2011 22:43
Theory behind the solid domain rotation in fluid using Bets property Riken CFX 0 October 28, 2009 09:51
Fluid - Solid Domain Interface Daniel CFX 6 February 15, 2009 18:09
Size of rotating domain Adam CFX 4 November 28, 2006 10:28
