August 16, 2011, 10:02 |
Convergence problem caused by wallscale
Roland Rakos
Rep Power: 17 |
I have read i earlier topics that in some cases the wallscale residual doesn't decrease. I calculate a 2D wing, the quad cells are extruded to one layer which is very thin because of the fine boundary layer elements. So the aspect ratio is not too high. In spite of this the residual of wallscale is not ok. Setting "double precision" was investigated but it didn't help the convergence... What can cause this rare error? Thanks Roland |
August 16, 2011, 18:30 |
Rep Power: 143 |
If the wallscale equation does not converge then almost certainly your mesh quality is terrible and the Navier Stokes equations won't converge either. Better fix the mesh quality.
Submerged fin, Convergence problem | supermouniette | FLUENT | 10 | July 6, 2009 10:47 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
3D Fluid Flow Convergence problem | Emily | FLUENT | 2 | March 21, 2007 22:18 |
CONVERGENCE PROBLEM - oil boiler | MM | FLUENT | 1 | February 15, 2007 05:24 |
Non Convergence of 3D Heat transfer cfd problem | Balraj | Main CFD Forum | 3 | December 9, 2004 00:24 |
