September 6, 2010, 06:47 |
local time step
sungho yoon
Rep Power: 17 |
Hello.
I'm doing a calculation which simulates a steam turbine diffuser. I generally use a local time step which I gradually increase from 1 to 50. This is generally okay for most of my cases. However, for some outlet boundary conditions, the calculation does not converge and the flow separates significantly. When I have these cases, I can often (not always!) make the solution converged by increasing the local time step to a very large number (say 200) I wonder what this means. Does it mean that my actual time step (delta t) is increased significantly and misses small time scale fluctuations? Kind Regards, |
September 6, 2010, 07:37 |
#2 | |
Rep Power: 143 |
You should not use local time stepping for the final run to convergence. Always use physical timesteps on the final run to convergence.
Your experience agrees with the comments on the FAQ about convergence in steady state simulations: http://www.cfd-online.com/Wiki/Ansys...gence_criteria |
Time step size and max iterations per time step | pUl| | FLUENT | 33 | October 23, 2020 22:50 |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 16, 2019 23:12 |
Forces in OF15 | richard | OpenFOAM Running, Solving & CFD | 180 | July 9, 2018 10:54 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
