May 31, 2009, 20:43 |
FSI with time interval remeshing ?
Rep Power: 17 |
I am doing a transient FSI simulation of a wing with Ansys Simulation in Workbench and CFX. and due to large deflections (the same order as the length), the mesh quality gets poorer with each time interval. Is there a way that I can Remesh the region around the wing instead of relying on the mesh interpolator, every X time intervals ? It seems to have been done in the literature with in-house codes but Is there a relatively easy way to do it in the Ansys Suite ? Thanks |
June 1, 2009, 04:53 |
SMN
Rep Power: 16 |
hi realanony87
sorry I don't know the answer,but : would you please help me with the error"the connection between cfx and external solver has died unexpectedly" in FSI modeling in CFX???? what does this error means & how can i solve this problem? |
June 1, 2009, 08:33 |
Rep Power: 17 |
It is probably due to an error from the Structural solver. Check the .out file from Ansys ( not the CFX out file) to see what went wrong. I cannot help you because it could happen due to many reasons.
June 2, 2009, 19:59 |
Rep Power: 21 |
Remeshing + FSI is not currently possible with ANSYS + CFX. But there's a lots of ways to maintain mesh quality for large deflections. Using a mesh stiffness of "Increase Near Boundaries" with an exponent of say 2 would be a starting point. Then you need to look at where the mesh is folding - and change the mesh motion boundary conditions, or add subdomain mesh motion, or insert sliding interfaces etc to imporve things. Sorry i can't be more specific; the best approach is always case dependent.
September 14, 2010, 05:32 |
different mesh stiffnesses of subdomains
Rep Power: 15 |
to play with mesh stiffness is very usefuel in case of large deflections. How is it possible, to define different mesh stiffnesses of subdomains? I just know this for a whole domain. So I have to control these complicated with if statements. Is there an easier way? Vinzent |
September 14, 2010, 09:04 |
Rep Power: 21 |
To get a different mesh stiffness in a subdomain you will need if() statements, but the inside()@ function should make this fairly easy, e.g.
if(inside()@subdomain1, meshstiffness1, meshstiffness2) |
September 14, 2010, 10:11 |
Rep Power: 15 |
stumpy, thank you very much!
this is, what i was searching for. vinzent |
September 17, 2010, 07:29 |
Rep Power: 15 |
Hello Stumpy,
when I try to define mesh stiffness with "inside" like your example following error occurs: ############################################## Error processing expression 'Mesh Stiffness'. Error at position 4. The condition expression in 'if' statement is not logical valued. Error processing expression: Mesh Stiffness = MS ############################################## Is there something missing? Vinzent |
September 17, 2010, 12:04 |
#9 |
Rep Power: 21 |
The inside() function returns 0 or 1 - I was assuming this was enough for CFX to evaluate if it's true of false, but perhaps not. Try if(inside()@subdomain1 > 0.5, ....
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
why did my time interval set for output nouse? | ShFlow | FLOW-3D | 2 | January 11, 2009 20:25 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Repeating same time steps (FSI). | cjtune | Siemens | 0 | February 19, 2003 23:05 |
unsteady calcs in FLUENT | Sanjay Padhiar | Main CFD Forum | 1 | March 31, 1999 12:32 |
