September 27, 2010, 09:39 |
2 magnets moving in a still fluid
Rep Power: 15 |
I am a relatively new CFX user and have an interesting problem that I hope someone may be able to help me with. I can't find what I am looking for in the ANSYS documentation. Essentially I have two magnets in a stationary fluid, and due to an externally applied load one of them will start to move past the other, which will be mounted on a spring and is therefore free. I would like to know if there's any way that it may be possible to calculate and couple the force between the two magnets as they move relative to eachother through the fluid, in CFX. My aim is to model the magnet on the spring as a mass-spring-damper system, with the magnetic force of attraction/repulsion constituting an external load and the fluid providing hydrodynamic damping. Can anyone help me please? I understand how to apply a time-varying external load to a structure using a Tabular Data input, but the challenge here appears to be introducing the coupling between the two magnets. Will it be necessary to use EMAG? Many thanks in advance for any advice. |
September 27, 2010, 19:20 |
Rep Power: 143 |
Not sure what you need to get this working, but it sounds manageable. Hopefully the EMAG option can do it. Coupling the EMAG stuff with a 6DOF solver should hopefully be possible but I can't guarantee that either.
You will just have to try it out and see what works. |
September 29, 2010, 04:22 |
Rep Power: 15 |
OK thanks Glenn, I'll give it a crack with EMAG. Unfortunately our license server has been down all week, so haven't been able to try anything.
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Modeling fluid flow over moving object | psd | Main CFD Forum | 0 | July 21, 2009 09:00 |
Moving a rigid body in a fluid | doum | OpenFOAM Running, Solving & CFD | 2 | April 4, 2007 09:09 |
moving wall and fluid | svh | FLUENT | 2 | September 30, 2004 07:33 |
Why FVM for high-Re flows? | Zhong Lei | Main CFD Forum | 23 | May 14, 1999 13:22 |
