Calculation for Turbulent Length Scale
Old   December 13, 2010, 06:07
Post Calculation for Turbulent Length Scale
Muhammad Aqib Chishty
aqib is on a distinguished road
Hello everyone,
I am using SST (Gamma-Theta) Model for the simulation of my Cascade T106A.
I have the problem regarding to set my Turbulent Length Scale value.
By Default it is 1. How should i select this value?
Any formula for that?
Does it effect on my results?
Give your opinion....
Regards:
Chishty
aqib is offline   Reply With Quote
Old   December 13, 2010, 16:22
Set the incoming and/or initial turbulence levels to match the experiments you are reproducing. The default is just a guessed value to give it a default value.
If you do not have experimental turbulence levels then your experimental conditions are not fully defined.
Old   December 13, 2010, 23:55
i am using FSTI=0.1 & 0.4
but can't specify the Turbulent Length Scale....
Any formula or theory for that, from where i can get that value....
Old   December 14, 2010, 04:50
As I now know you are using Fluent I can't tell you exactly which options to choose but I am sure Fluent has similar options to CFX. To get the equations to convert between turbulence intensity, energy, length scales etc get a decent turbulence textbook such as "Turbulence modelled for CFD" by Wilcox.
Old   December 14, 2010, 05:24
ok i will read that book and come back to you soon....
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 07:22
Integral Length Scale vs Turbulent Length Scale Scott Nordsen FLUENT 2 January 20, 2014 01:17
calculation of eddy length scale nathalie FLUENT 0 February 2, 2009 12:05
Warning 097- AB Siemens 6 November 15, 2004 04:41
