Value below interpolation range
Old   December 19, 2010, 09:53
Default Value below interpolation range
Clif is on a distinguished road
Determining the change in heat capacity of the material in the form of tabulated values (temperature, heat capacity) in the section of the function referred to as Function teplo emk further expression in writing Function teplo emk (T), but get an error:
PROBLEM ENCOUNTERED WHEN EXECUTING CFX EXPRESSION LANGUAGE |
| The CFX expression language was evaluating: |
| Specific Heat Capacity |
| The problem was: |
| Value below interpolation range |
| FURTHER INFORMATION |
| The problem was encountered in executing the expression for: |
| Expression teplo emk |
| The complete expression is: |
| Function teplo emk(T) |
| The error occurs on sub-expression: |
| SCALAR_0CELValueMa |
| BACKGROUND INFORMATION |
| The error was detected at one location. The same problem may be |
| present at other locations - that has not been investigated. |
| The following values are for the first location which has the |
| problem. |
| END OF DIAGNOSTIC OUTPUT FOR CFX EXPRESSION LANGUAGE
In what may be the reason?
Clif is offline   Reply With Quote
Help on 2D interpolation in StarCCM+ madhuri Siemens 1 May 30, 2017 03:20
urgent help needed (rhie-chow interpolation problem) Ardalan Main CFD Forum 2 March 18, 2011 15:22
Surface interpolation schemes and parallelization jutta OpenFOAM Running, Solving & CFD 0 February 25, 2010 14:32
momentum interpolation for collocated grid Hadian Main CFD Forum 4 December 25, 2009 07:25
Value above interpolation range, ERROR #001100279 eslam CFX 2 January 10, 2008 13:58
