RMS Courant Number
Old   December 20, 2010, 15:36
Default RMS Courant Number
FRANCISCO SERVIGNA
SERVIGNAF is on a distinguished road
hi...how to calculate the RMS courant number.....is (velocity*deltaT)/element size?? in my project I have a courant number values equal to 999.99, where this affects the solution to my problem? and how I can do to lower that value?
Thanks...
SERVIGNAF is offline   Reply With Quote
Old   December 20, 2010, 17:04
The documentation describes the calculation of Courant number.
Don't get too excited about the Courant Number. Do a time step sensitivity check instead to give you the time step your model can run at.
To lower Courant number you run a smaller time step.
Old   December 21, 2010, 07:30
FRANCISCO SERVIGNA
THANKS. But I still doubt, do not know if it is conceptual, I need to see the cooling behavior of a solid body by convection, for about 10 hours, then if I use this time as total transient simulation, it appears a number of high courant. Will need to divide this time segment? or just change the steps of time?
Old   December 21, 2010, 16:07
Joshua Counsil
Josh is on a distinguished road
I like the adaptive time scheme. Set a reasonable residual value (you'll have to determine what this is) and the program will lower or raise the timestep size based on the convergence speed. It will give you an approximately appropriate timestep size.
Josh is offline   Reply With Quote
courant
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
RMS Courant Number vs MAX Courant Number zoozoozoo Main CFD Forum 3 June 12, 2012 13:44
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
