radiative heat transfer in participating media |
December 25, 2010, 14:47 |
Hi everyone and merry xmas!
I'm modeling heat exchanger with two fluids separated by thin wall in CFX 12.1. One fluid is air and other is the exhaust gas modeled as a mixture of CO2, H2O, N2 and O2. The exhaust gas temperature is about 1250 K so I need to include radiation in participating fluid in my flow&heat transfer calculation.The problem is that when I set both fluids and assign them to the separate fluid domains (each on the oposite side of the wall) to flow throught the heat exchanger, I can not set thermal radiation option. In that case thermal radiation field in Domain's Fluid Models definition tab can be set only to "none". If I delete one of the fluids then I can set all radiation properties and solve my model. But in such case the exhaust gas is presented in the domain where air should be. So my results are not right even if I set emissivity factors to minimum for the walls of the "air" side to prevent exhaust gas from absorbing and emitting heat energy on that side of heat exchanger. Could someone please help me? |
Radiative Heat Transfer | kamakura117 | STAR-CCM+ | 0 | July 19, 2010 19:51 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
Conjugate heat transfer problem with porous media | piko | Siemens | 1 | April 17, 2009 15:41 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
radiative heat transfer | Tim | FLUENT | 0 | February 20, 2004 13:28 |
