January 10, 2011, 15:57 |
Arithmetic mean of velocity (steady - state)
sirLentschi
Rep Power: 15 |
I am using CFX 12.1 (in steady state mode)to simulate flow in hydraulic pumps. Because of instable phenomena at the examine loadcases the steady - state solution does not really converge but fluctuates with an almost constant amplitude (=velocity at 1000 measurement points in a spiral case). Now I want to calculate the arithmetic mean of these velocity values at the defined points for comparing with measurement values.Therefor I create a perl code to import the coordinates of these measurement points in CFX-Post, to calculate the velocities (probe(Var)@Point) at these points and to export the velocities (.csv chart).but now i need the arithmetic mean of the velocities vs. iteration-numbers to get a "correct" solution for comparing. So how can I reach this (preferred in CFX Post 12.1)? Thank you for your advice in advance. regards markus |
January 10, 2011, 16:43 |
Rep Power: 143 |
Surely you are not asking "how do I calculate an arithmetic mean"?
January 10, 2011, 17:26 |
sirLentschi
Rep Power: 15 |
So how do I calculate an arithmetic mean of velocity vs. iteration number after steady state calculation in CFX-Post 12.1 at the desired measurement POINTS (no area/line)?
Any idea?i hope this is possible! Regards Markus |
January 11, 2011, 06:18 |
Rep Power: 143 |
You have the values at the points versus time, so stick it into excel/matlab/python/whatever and calculate an arithmetic mean. You cannot do this easily in CFD-Post.
false time step implementation for steady state | Kushagra | CFX | 1 | June 22, 2008 19:06 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
regarding steady state discrete phase calculations | hajszan_gyula | FLUENT | 1 | February 28, 2006 01:32 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 14:37 |
Steady state formulation of turbulence ?? | Jitendra | Main CFD Forum | 1 | June 27, 2000 18:49 |
