Line as function of one coordinate
Old   January 8, 2011, 08:00
Default Line as function of one coordinate
Andrew High
handrew is on a distinguished road
Hello I need to write expression of temperature at line as a function of coordinate y. Coordinates x and z are constant. I tried to look in help, but I had found no solution. One possibility is to export it as chart values, but it would be too complicated, because I need to work with other values in CFX post.
Thank you for answers
handrew is offline   Reply With Quote
Old   January 12, 2011, 11:41
Bharath kumar
bharath is on a distinguished road
hi handrew,
i don't know the solution exactly.but i have an idea of doing this.make an expression like A = Y (i.e CFX variable),and a function named B with 1D interpolation scheme(like y=0 m;t=100deg c and y=10 m ;t=1000 deg c) and another expression named C = A(B).
It may work for your need.
bharath is offline   Reply With Quote
Old   January 13, 2011, 00:55
This is easy to do with a CEL expression function or 1D interpolation function. Just make the input variable y and the output variable temeprature.
Old   January 15, 2011, 15:54
Andrew High
That s what I want to do. But i don t know the right syntax. I suppose that I should use function probe, but I don t know how to use it with line ( with variable y). I didn t find the solution in help either.
Old   January 16, 2011, 17:21
In CFX-Pre, click the 1D interpolation function option. It will sort the syntax out for you.
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
OpenFoam 14 installation problem gfcoppola OpenFOAM Installation 20 November 2, 2007 13:38
