February 15, 2011, 16:53 |
Steady state flow over cylinder
Ugly Kid Joe
Rep Power: 15 |
I am trying to show von karman vortex street for a reynolds # of 200 (I know it is a simplest CFD problem, pls excuse me). I tried to run a steady state simulation in CFX and I dont see any vortex shedding. Its looks all symmetric. I tried changing everything. Convergence, boundary layer, Advection scheme number of iterations etc etc etc.
I ran the same case in FLUENT using Green Gauss Node based scheme. Same BC and Same initial conditions same mesh, and it shows vortex shedding. What could be the problem ???? I am attaching the velocity contours. Thank you guys. http://img69.imageshack.us/i/cfx.png/ http://img13.imageshack.us/i/fluent.jpg/ Thank you. |
February 15, 2011, 17:29 |
Joshua Counsil
Rep Power: 17 |
February 15, 2011, 19:34 |
Ugly Kid Joe
Rep Power: 15 |
I realize that vortex shedding is not steady. But I need to know why is the contour plots different in FLUENT and different in CFX. At least the contours in CFX should give some kind of unsymmetrical vortex ???
It probably is the type of solver I am using or even the residuals at the end of convergence. CFX does a better job converging the solution (up to 10^-8). Am sure there may be other ways to converge the solution in FLUENT too, but who cares !!!!!!! Thanks anyways. Appreciate your help !!!! |
February 16, 2011, 04:59 |
Rep Power: 143 |
If CFX has given a symmetric solution then that is correct - when the flow is averaged out it will be symmetric. But the physics will be totally wrong so forget the steady state solution. Comparing a steady state CFX and a steady state Fluent simulation of a model which is transient is totally meaningless.
As Josh says, if the flow is transient you need to run a transient simulation. |
February 16, 2011, 15:04 |
Ugly Kid Joe
Rep Power: 15 |
@ Josh and Glen : You guys kick Ass man !!!
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
initialization of flow field to enhance convergence rate to steady state | vfico | Main CFD Forum | 0 | September 9, 2009 11:23 |
initialize flow field with steady state solution | holg | FLUENT | 0 | July 13, 2009 17:10 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
