August 17, 2014, 19:56 |
Age of Air and Source Conflict
Michael Smith
Rep Power: 12 |
Hi all,
I am doing an analysis in a carpark, and want to calculate age of air and CO concentration. When I run the sim with both setup, I get the CO concentration but age of air doesn't seem to increase (or calcualate) and remains at essentially zero. If I don't add the source term age of air calculates fine. Ideas why the source prevents age of air? Cheers, Mike |
August 18, 2014, 06:27 |
Rep Power: 143 |
Can you post your CCL?
August 18, 2014, 20:58 |
Michael Smith
Rep Power: 12 |
See attached.
Thanks! |
August 18, 2014, 22:05 |
Rep Power: 143 |
It looks like you have not set a source term properly. You have set the source term to "Density", this should be set to 1.0.
SUBDOMAIN: AoA Coord Frame = Coord 0 Location = B2519 SOURCES: EQUATION SOURCE: AoA Option = Source Source = Density END END END It worked for me on the benchmark example. |
August 18, 2014, 22:46 |
Michael Smith
Rep Power: 12 |
Hi Glenn,
Thanks for the advice. So the source term has to be constant (ie, 1) rather than density? Density is the input I got told to use by Leap (Ansys provider). Hmm. On another note, what did you use to assess the CCL? Cheers, Mike |
August 18, 2014, 23:01 |
Rep Power: 143 |
Are you sure you are referencing the Density correctly? In fact that is probably your problem - if the Density function is zero then nothing will happen.
I suspect that if you have an incompressible simulation then the density variable is not present. I am not sure about that, but I think that is the case. The ANSYS guy is probably right, you probably do need to integrate density rather than a constant. So write a CEL expression which defines the density for the material properties, and then use that variable for the source term. |
August 19, 2014, 02:15 |
Michael Smith
Rep Power: 12 |
That will be exactly it. I'm assuming the Source "Density" is for air at 25degC, but I have set a custom fluid to allow calculation of CO.
Ok... so how do I specify density for my material to use as a source term? |
August 19, 2014, 03:07 |
Rep Power: 143 |
I've just tried a few things and what you have done works fine for me. I used the simple benchmark simulation with a variable composition mixture with both Density and a constant (1) as the source term factor. Both worked fine.
So I recommend you do the same and try to get the benchmark simulation working, as I can confirm it definitely does work for me. Then you can start debugging your simulation. |
August 20, 2014, 22:41 |
#9 |
Michael Smith
Rep Power: 12 |
Yip, you're right. A simplified model worked for me with Density as well.
Well that's good, now at least I know it can work, and I've just got something muddled elsewhere! Thanks Glenn! Mike |
irregular model simulation with chtMultiregionFoam | lg88 | OpenFOAM | 59 | July 28, 2016 11:44 |
Forced Convection: 2D fan (forced air flow source) | acdc_cfd | FLUENT | 0 | March 17, 2014 08:34 |
mean age of air calculations | eric | Siemens | 4 | December 10, 2011 09:39 |
age of air calculations | tom | Siemens | 2 | October 28, 2007 06:26 |
Age of Air In Star-CD | Ted Crilly | Siemens | 1 | February 19, 2005 19:50 |
