March 11, 2011, 02:53 |
Wave simulation in CFX
Hi, I am simulating waves in CFX by specifying an inlet velocity profile obtained from linear wave theory. The waves I make start off nicely but then suffer substantial damping as they move along the grid. I have read some papers and this damping seems to be a common problem, but not to the same extent as in my simulations. Any ideas what this is due to? Is CFX capable of modelling such waves?
March 11, 2011, 04:42 |
Rep Power: 143 |
Yes, CFX should be capable of modelling waves with little dissipation.
Check your simulation is well converged, your mesh quality is good and you are running second order space and time differencing. For spacial differencing I would use hybrid with a blend factor of 1.0 as that is pure second order with no highly dissipative first order. |
March 16, 2011, 17:46 |
I have done all of that but I am still experiencing excessive dissipation. Any other ideas on what i could do?
March 18, 2011, 06:25 |
Rep Power: 143 |
That's the basics covered, so time to start looking a bit deeper. Lots of things to look at. Here's a few ideas to start you off:
1) single versus double precision 2) free surface sharpening algorithm 3) mesh quality (have you tested on a hex grid with aspect ratio 1?) 4) mesh size 5) time step size |
March 18, 2011, 06:47 |
Ok, so I'll have a look at these aspects! Thanks for the advice. I really appreciate it.
August 21, 2012, 16:59 |
Wave Modeling in Ansys CFX
Hesam
Hi
I need to generate wave in ansys cfx, but how can i model it??????? plz Help me |
August 21, 2012, 19:31 |
Rep Power: 143 |
Do the free surface over a bump CFX tutorial.
September 5, 2012, 12:05 |
Hesam
September 21, 2012, 19:29 |
Tank Modeling
Hesam
Hi
I want simulatie a tank that has 1.5 m height and 1m of it cover with water in ansys cfx. How can i do it? Please Help |
September 24, 2012, 20:39 |
Rep Power: 143 |
You have to adapt the tutorial example to your case. You can describe your wave with a CEL expression or other function. If you do not know how to do this then do more tutorials to learn CEL and other general functions.
October 3, 2012, 13:37 |
Regarding waves
#11 |
niru
I want to models waves in CFX or fluent. Can I get any tutorial file to do this?
October 3, 2012, 15:57 |
#12 |
Erik
Rep Power: 23 |
Did you guys all just get the same homework assignment?
October 4, 2012, 05:13 |
#13 |
Hesam
October 4, 2012, 05:30 |
#14 |
Hesam
November 29, 2012, 05:50 |
#15 | |
hoannv
Dear Sorenasrn ! Could you tell me more about making vWave by applying velocity in inlet,.. i have already tried many time but no result... Brg |
October 22, 2015, 03:02 |
Wave generation
#16 |
Fluidflow
Rep Power: 10 |
Hi friends
I am trying to simulate a surface wave in CFX, but I do not know how I can generate a wave. As far as I know we must write an expression( For example eta=a*sin(bt-cx)) and use it as an inlet velocity but I do not know how exactly?Is there any tutorial? Best Regards |
October 22, 2015, 05:38 |
#17 |
Rep Power: 143 |
It is straight forward, just set the inlet velocity to your CEL expression. There are many examples of using CEL expressions in the CFX tutorials.
You can also do this with moving mesh (make an end wall move to generate waves) or with an initial condition (have a blob of fluid initially above the water level which splats down) or even a mass source term (to generate and consume fluid). There are lots of ways to do it. |
October 22, 2015, 11:27 |
#18 |
Rep Power: 11 |
Hi All
Just to let you know (if you do not already know it), that in Fluent there is an open channel model with wave boundary conditions already implemented (from airy first order theory till 5th order theory). I hope this helps. To give you an idea http://www.ansys.com/Products/Simula...mpact+Analysis |
November 23, 2015, 04:52 |
#19 |
Fluidflow
Rep Power: 10 |
Hi
I am going to simulate a surface wave on a submarine. I am using the CFX software. For simulating the wave I want to utilize the velocity inlet way. Based on my wave profile the u and w velocities are uvel=exp(0.4z)*sin(2t) and wvel=exp(0.4z)*cos(2t). The mean velocity of water is 5 m/s.The length of the domain is 75 meters so I need 15 seconds ( 5*15=75) to ensure the created wave reaches to the outlet. I have some questions: 1- For input velocities I must use u=5+uvel and w=wvel and v=0??????? 2= During simulation I set the timestep equal to 0.002. About 1.2 second, the simulation diverges because of the great change in w velocity. So if I use 0.001 as its timestep it takes about 2 weeks . What should I do? Isn't 0.001 too small? Tnx |
November 23, 2015, 05:07 |
#20 |
Rep Power: 143 |
1: That would seem to make sense.
2: These FAQs discuss the general approach in these situations: http://www.cfd-online.com/Wiki/Ansys...gence_criteria and http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F |
Wave Simulation | solimcfd | CFX | 48 | December 27, 2016 05:26 |
Small cluster configuration for pump simulation at CFX | Nevel | Hardware | 2 | April 7, 2014 06:07 |
solving ocean wave with Fluent or CFX? | gholamghar | Main CFD Forum | 1 | March 21, 2009 12:49 |
Simulation of turbine cascade in CFX. | Jonas Pedro Caumo | CFX | 0 | December 9, 2006 13:54 |
mesh from Workbench Simulation to Cfx Pre? | Dai | CFX | 6 | November 11, 2006 12:19 |
