Mass flow @outlet is greater than mass flow@inlet
Old   July 10, 2015, 06:03
Default Mass flow @outlet is greater than mass flow@inlet
Mayur Bhandari
bmayurm is on a distinguished road
Hello dear all,
I am simulating a decanter (rotating frame). I have a boundary conditions are as @inlet mass flow rate is 4.16 kg/s and @outlet average static pressure is zero. After simulation in post-processing I found that @outlet mass flow rate is 4.45 kg/s which seems to be invalid.
Please tell me that at most general, what would be the conditions for such mismatch situation? Does meshing affects? How?
Please help me
bmayurm is offline   Reply With Quote
Old   July 10, 2015, 06:19
Assuming this is a steady state simulation where the inlet must balance the outlet: It means you are not adequately converged. Run the simulation for more time steps.
For transient simulations it is a bit more complex.
Old   July 10, 2015, 06:24
Mayur Bhandari
Thank you for replying Ghorrocks.
Yes, It is steady state incompressible simulation. I gave 100 iteration. Should I gave some more hundred so that it will have good convergence?
Old   July 10, 2015, 06:26
The residuals are what you should be watching to see if you are converged or not. And in this case as you have a problem with conservation I would use imbalances as well. You use as many iterations as are required to achieve the convergence you need.
Old   July 10, 2015, 06:28
Mayur Bhandari
ok thank you
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
mass flow inlet and pressure outlet with target mass flow rate Zigainer FLUENT 13 October 26, 2018 05:58
Convergence problem with target mass flow rate ADL FLUENT 2 May 29, 2012 21:11
mass flow Wenbin Song FLUENT 0 September 27, 2005 13:00
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 19, 2003 14:03
