Overflow error
Old   July 11, 2014, 10:49
Default Overflow error
Ali ebadi
Aliebadi is on a distinguished road
آHello every one !
I am trying to model a two phase channel including water and air. I specify the velocity of water and air as the inlet boundary condition and average static pressure equal to zero for the outlet. The analysis type is transient. 100 kpa pressure and slight velocity are considered as initial condition. But every time that I run this code, program stops by overflow error. Who can help me ?
Aliebadi is offline   Reply With Quote
Old   July 13, 2014, 07:32
Have you read the FAQ? http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F
Are you sure your exit boundary is correct? Check the flow over a bump tutorial for how they do it.
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
