April 19, 2011, 06:23 |
PCV valve simulation - FSI?
Rep Power: 15 |
Can anyone advise me on how to simulate flow through PCV valve? Do I use FSI method and if so, 1-way or 2-way? Thanks a lot.
April 19, 2011, 06:42 |
Rep Power: 143 |
What is a PCV valve?
April 19, 2011, 08:20 |
Rep Power: 15 |
Hi Glenn,
PCV reffers to Positive Crankcase ventilation system. There is quite a good description on this link incl. images. http://www.buet.ac.bd/me/icme/icme20...ME05-FL-08.pdf Basically, valve of semi cylindrical/conical shape with small cylinder inside which is attached to valve via spring. The flow of air through valve is regulated by position of this small cylinder (simillar to ball valve or check valve). I have no experience with immersed solid simulations, I suspect this is it and just want the advise which type of Ansys simulation to use to find out what preload should the spring have to maintain the piston/culinder in certain position to allow certain volume flow. Thanks a lot |
April 19, 2011, 10:33 |
Edmund Singer P.E.
Rep Power: 20 |
Are you sure you need FSI? Can you just model this as a series of solutions with the valve in fixed position and get the forces on it that way?
If you feel you need a transient moving valve solution, please look up the ball valve tutorial/example that is well known in CFX. They have done that example with moving mesh and immersed solids (I believe). |
a problem of valve simulation in openfoam | xck1986 | OpenFOAM | 2 | January 21, 2011 20:08 |
FSI simulation is DEAD SLOW | Lance | CFX | 6 | September 12, 2009 09:00 |
valve simulation in ansys cfx | Franco | CFX | 0 | July 3, 2008 05:33 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 04:08 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 10:06 |
