[CFD POST ] Averaging Values for one direction
Old   April 27, 2011, 07:49
Default [CFD POST ] Averaging Values for one direction
Max
max3.2 is on a distinguished road
I've got a little Problem with Post. I am simulating a Channel Flow where x is flow direction, y is depth and z is height. For calculating some loss coeffs (a quotient of different pressures), I used the areaAve expression at different Planes in x-normal-direction before and behind a blade profile, and so getting a constant value.
Now I'm trying the following: With still fixed x-value (the Plane Location), I want to average the variable value (TotalPressure) in the y-direction for every height (z) for plotting a loss coeffs vs. channel height chart.
I cant find a y-average function or something like that....can anybody help?
Thanks in advance.
Best Regards
Max
max3.2 is offline   Reply With Quote
Old   April 27, 2011, 09:39
stumpy is on a distinguished road
I guess you could create line objects rather than planes, then use the lengthAve function.
Note that when averaging Total Pressure you should use massFlowAve, not areaAve. areaAve can be used for Static Pressure.
stumpy is offline   Reply With Quote
Old   April 27, 2011, 10:11
Max
Thanks for the hint =)
If i get what you mean: Yes, i can create lines with z,x=const and the use lenght average on each. then create a plot with the linevalues. the experimental data i have to compare to deals with approx. 100 values, also, there is a thesis with a plot with a lot more points (curves are really smooth).
isnt there a way to do this auto? i thought about integrating and dividing by the (constant) lenght. but i still cant find a way to do it so i get an exp oder var which is only a f(z)
Old   April 28, 2011, 10:37
Max
Nobody?
Isnt there any way to "collapse" plane values (yAve()@Plane, etc..) to eliminate the y-coord? Or any other way to extract such data,even to a dat file or smth..
Old   May 4, 2011, 03:49
Max
A little bit of news: I contacted CFX Support and maybe getting an answer soon. It seems that there is a Script doing it. I will post a solution if there's one.
Old   May 4, 2011, 07:23
Use the record session option in CFD-Post to record a few steps like making a plane and extracting values. Then edit the session file and insert some perl and you have it.
Old   May 4, 2011, 14:15
Max
CFX supported me with a session file doing so.
Max
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
post data starcd_learner Siemens 0 February 1, 2006 11:24
Adding all the values in a post register Cb Siemens 3 March 11, 2005 13:40
post processing CL values Joe Bryant FLUENT 2 October 18, 2004 04:17
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 11:59
