May 10, 2011, 04:19 |
transient analysis
Govindaraju
Rep Power: 17 |
I am doing transient analysis in a branched pipe having different cross sections ( one inlet and two outlets)
I assumed the fluid is a non Newtonian. I assumed the central maximum velocity at the inlet is 0.8m/s and the inlet flow is fully developed flow now I want to apply pressure pulse (sinusoidal) at the inlet. Kindly give an idea to set up the boundary conditions. Thank you kmgraju |
May 10, 2011, 14:30 |
Max
Rep Power: 15 |
write a profile data with the spatial fields in place and time. import this as user function and use as inlet expression.
if its only a mean pulse, just use an expression. EDIT: sorry this was to easy. i assume you already set velocity at the same region? maybe its possible with the user function to use more than one variable. i have never tried it this way |
May 10, 2011, 23:55 |
transient analysis
#3 | |
Govindaraju
Rep Power: 17 |
I am new to this user function.Can you please explain little more. my velocity equation is : Umax( 1-r^2/R^2) I set the above expression in the inlet. Now I would like to apply a pressure pulse for 1 sec at the same inlet The pressure pulse may be square step function or step sin function for 1 sec How to set this pressure pulse condition at the inlet again. What to set in the Global initialization. Please help me to write user function as you said it was to easy to proceed further. Thank you Regards Govind |
May 11, 2011, 02:18 |
Rep Power: 143 |
Are you trying to define both the velocity and pressure at the same boundary? This is not possible. It is mathematically badly-posed.
Unless you want to switch from a velocity inlet to a pressure inlet, that can be done (although it is a bit weird and will have convergence problems). |
May 11, 2011, 04:30 |
Max
Rep Power: 15 |
Just for the record - to use profile data, build a csv with following header
[Name] InletBC [Spatial Fields] x,z,t etc.. [Data] x [mm],z [mm], t[s], Velocity[m/s], Total Pressure [Pa] etc.. 1,1,1,10,10000 more data but, as G. Horrocks said, both pressure and velocity is not possible at the same time |
2-D airfoil transient analysis | mike | FLUENT | 1 | July 15, 2017 04:33 |
FSI Transient Thermal Analysis | Abduri | CFX | 1 | January 1, 2017 22:54 |
Transient Thermal Analysis in Ansys Workbench | khurram1 | ANSYS | 0 | November 22, 2010 02:40 |
Transient Analysis tutorial | Bharatkumar | FLUENT | 0 | June 4, 2010 08:25 |
Transient analysis with turbFoam very high Courant nr | hardy | OpenFOAM Running, Solving & CFD | 13 | November 19, 2008 13:36 |
