CFX v12 adding reattachment modification to sst model
Like Tree1Likes
Old   May 13, 2011, 05:18
Default CFX v12 adding reattachment modification to sst model
ovechkin is on a distinguished road
I need to add the reattachment modification to the Shear Stress Transport model, but I´m not sure how to do it. I assume i need to add some lines in the definition file..
can someone give me a clue how to do this?
thanks a lot,
ovechkin
ovechkin is offline   Reply With Quote
Old   May 13, 2011, 06:56
..got it. just add "SST Reattachment Modification = On" to Turbulence Model in Command Editor..
Old   May 13, 2011, 06:59
Raashid Baig
cfd_newbie is on a distinguished road
Do you know what is the SST Reattachment Modification how is it different from the standard SST ? Why and where is it used. Can you share some references ?
cfd_newbie is offline   Reply With Quote
Old   May 13, 2011, 07:08
I am not familiar with the reattachment model. In fact I did not even know it was in there. Do you know any details about it, or have any documentation on it?
Old   May 13, 2011, 07:45
Unfortunately I don't have any references/documentation on it. All I know is that the Reattachment Model accounts for an additional production of kinetic energy in seperated shear layers.
We use it for simulation of a turbulent premixed combustion process
Old   June 27, 2011, 15:50
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
It is basically related to fact that the baseline SST (original SST) predicts the larger separation bubble than the experimental values. This is due to the wrong prediction of reattachment point (boundary layer attachment at further downstream location). Therefore the RM modification was introduced in production term to account for the realistic separation bubble length and hence earlier attachment. It is to be noted that this limiter is not activated in the attached flow and hence base line sst is fully recovered.
Keeping in view above discussion, base line SST model has difficulties in predicting the stall point correctly and simulation often stops due to premature numerical stall.
Best Regards
Far
Mazze[ITA] likes this.
Far is offline   Reply With Quote
Old   March 4, 2014, 03:59
swm
swm's Avatar
swm is on a distinguished road
In version 14.5,it seems that it is NOT allowed to add this to TURBULENCE MODEL?
swm is offline   Reply With Quote
Old   June 3, 2016, 19:51
ali
alinik is on a distinguished road
folks,
I am using CFX v15.1
I cannot add this line to the command editor.
I constantly receive this error:
ERROR
CCL validation failed with message:
Error: Sub-object 'FLUID MODELS' is not allowed in /
any ideas? any kind of help is much appreciated.
alinik is offline   Reply With Quote
Old   June 4, 2016, 00:52
Why not just set it up in CFX-Pre and see what syntax it uses?
Old   June 4, 2016, 15:35
ali
CFX 12 and 15 which I have on my machine do not have this option in the advanced turbulence control. According to this post there should be a way to get away around this problem.
I use the same syntax that people have recommended here but I am getting the error I said.
I suppose some people have already solved this problem.
Really appreciate it if someone can help me out with this issue.
Thanks,
Ali
Old   June 5, 2016, 06:20
My understanding is the options are available in CFD-Pre if your licensing allow those options. If you can't see the options then your licence does not support the advanced turbulence models and therefore putting it in via CCL will not help as the solver won't accept it.
Old   June 5, 2016, 15:40
ali
I do not think it is a license issue while I have the full license.
There should be some other way. The way this thread had initially started suggests that there is some alternate method for enabling this option using command editor.
Any kind of help is much appreciated folks.
Thanks,
alinik
Old   June 5, 2016, 20:13
If you look in the <CFX_ROOT>/etc/RULES file and search for the term it gives you some hints to the syntax. This might help you.
If that does not work post the CCL you are trying to use on the forum.
Old   June 5, 2016, 23:12
ali
Thanks man for the info.
I checked the file and found the syntax in the file.
It is actually the 8th line in the following text.
in the command editor I write this line according to ovechkin and get the error I said.
CONTEXT: SST
Optional Parameter List = \
Eddy Viscosity, \
BC TKI Factor, \
BetaStar Coefficient, \
Compressible Production, \
A1 Coefficient, \
Optional Child List = \
BUOYANCY TURBULENCE, \
K OMEGA REGIME, \
K EPSILON REGIME, \
TRANSITIONAL TURBULENCE, \
PRODUCTION LIMITER, \
CURVATURE CORRECTION
END
Old   June 5, 2016, 23:17
Further down in the RULES file is where it shows the syntax of the specific element. It says the default value is "No". So I assume the values it is looking for is "Yes" or "No". That's just a guess.
Old   June 5, 2016, 23:30
ali
This is what I found further down.
What shall I do? Shall I change the "No" to "Yes"?
PARAMETER: SST Reattachment Modification
Description = Determines whether the reattachement modification is \
used in the SST turbulence model
Parameter Type = Logical
Solver Name = LSSTRM
Default = No
Old   June 5, 2016, 23:43
This is a beta option and so is not documented anywhere. You have to figure it out.
In this case the easiest way to activate it is in CFX-Pre. Go to edit/options/general and select "enable beta features". Then go to the turbulence model options, select SST and the reattachment model will be visible under advanced turbulence control.
Old   June 7, 2016, 10:12
Far
Sijal
As per my discussion with F. Menter, he said that "Reattachment model is not physically correct".
Thats why now I dont use this option anymore.
Old   June 7, 2016, 21:33
Did he explain what is wrong with it?
Old   June 8, 2016, 13:41
ali
Glenn
Thank you for your reply. I have enabled beta features but there is still no sign of SST Reattachment modifier. Any clue what to do?
Sijal
Thank you also for your comment. What do you suggest we should do if we want to control separation?
Thanks,
Ali
Low Reynolds Number SST Model Josh CFX 41 June 4, 2023 19:00
[ICEM] Proper way to name boundaries on 2D model for use in CFX? RossFS ANSYS Meshing & Geometry 4 November 10, 2011 02:38
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
Turbulence model for CFX moving mesh songxguan CFX 7 June 28, 2009 21:05
Help: 2D model in CFX 5.5 Dejun Jing CFX 1 July 24, 2002 00:25
