[CFD Post] Surface streamlines not located where needed |
July 7, 2011, 10:18 |
Stuart
Rep Power: 25 |
I've plotted the Wall Shear X on two surfaces and where it's negative I get boundary layer separation (see image). I have put surface streamlines so that I can see the circulating fluid paths but CFD-Post only ever puts the streamlines so that they go around the separation region, and I've put 1000's of streamlines on. How can I get CFD-Post to put streamlines in the separation region? Thanks |
July 7, 2011, 19:13 |
Rep Power: 143 |
Manually define a point in the separated region and use that as the seed point for a streamline.
[Gmsh] gmsh and boundary layers | kanuk | OpenFOAM Meshing & Mesh Conversion | 11 | August 14, 2015 12:35 |
trying to simulate two-phase jet flow with particles in surface injection | ajkratos | FLUENT | 5 | March 3, 2015 21:33 |
[Gmsh] Default Faces on Boundary Layer | axel | OpenFOAM Meshing & Mesh Conversion | 8 | February 17, 2011 07:47 |
Help needed with free surface simulation | Mark | CFX | 4 | October 27, 2006 12:07 |
help needed: cone-shape surface | Y. Guo | Siemens | 4 | July 31, 2000 17:56 |
