How to use sas turbulent
Old   August 13, 2009, 05:17
Default How to use sas turbulent
dss
flyingd is on a distinguished road
Hi:
I want to use sas turbulent model to calculate tubulent.
But I don't konw what I will pay attention to .
Wish every one gives me some suggestion.
Thinks!
flyingd is offline   Reply With Quote
Old   August 13, 2009, 06:22
Only consider using these advanced turbulence models such as SAS once you know exactly what you are doing and you have shown the simpler turbulence models are not adequate.
Glenn
Old   August 13, 2009, 22:41
Default SAS setting
dss
Hi: Glenn
Thinks for your suggestions.
I know the SAS turbulent model's idea, but I use LES to simulate the turbulent, the results are good.however, I change turbulent model to SAS model, the results are not good. I use the same time step. I guess perhaps
some paremeters which I set are not good.
So, I want to ask for setting methods on SAS model.
Thinks!
Old   February 16, 2010, 11:11
Default SAS source term Qsas
Gert Lindner
hungryfish is on a distinguished road
F. Menter described in his paper [Revisting the turbulence scale equation] some test cases, e.g. for self-similar flows (Csas=0.54 for a round jet). I can find in the latest theory guide (12.1) that the default value in CFX is set to Cs=0.11. The question is, how can I change the value of Cs ?? The documentation (p.86) indicates compliance with zeta2=3.51 (== SAS2 Coeffiecient in CFX-Pre) , sigma_Phi=2/3 (diffusion constant), but what means SAS1- SAS3- Coeffiecient?
Regards
Gert
hungryfish is offline   Reply With Quote
Old   June 4, 2011, 02:04
Smile
mohammad
mohammad is on a distinguished road
Hi Dear Gert Lindner,
Have you found your answer? would you please tell me useful info you have about SAS?
Regards
mohammad is offline   Reply With Quote
Turbulent Boundary Layer on a Flat Plate Hoshang Garda FLUENT 1 November 27, 2013 10:24
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
low turbulent reynold number C-CARE CFX 4 March 12, 2004 06:36
About low Re number turbulent flows gorka Main CFD Forum 13 April 2, 2003 05:19
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
