Function integral over time
Like Tree1Likes
Old   June 8, 2011, 07:15
Default Function integral over time
GAO
Andrew
GAO is on a distinguished road
Tell me please, is there any possibility to use Ansys CFX time as a parameter in the formulation of transients problems. In the standard features you can not take the time integral. Is there a function integral over time? Or subroutine, which allows to produce a similar action. I'll be very grateful to you for any help in my problem.
GAO is offline   Reply With Quote
Old   June 8, 2011, 08:06
What do you want to take the time integral of?
Old   June 9, 2011, 03:37
GAO
Andrew
For use as a criterion for stopping the calculation
Old   June 9, 2011, 06:51
Sure - note there are already lots of stopping criterion built in so are you sure you need to implement your own?
But what do you need to do the time integral of?
Old   June 9, 2011, 08:01
GAO
Andrew
For example, we put on the surface of the paint brush, and we want to calculate what weight we are already done. In fact, we can change the flow of paint in each time, so I want to know how much paint has been applied to the desired point in time. That is the problem confined to the creation of a counter weight of the paint to a certain time.
Or the inverse problem - we have a certain volume of paint, we are doing with various pitch. How much does it for painting?
Old   June 9, 2011, 08:13
Arrgh! I did not ask for an example of a time integral, I know very well what time integral is.
What variable do you want to take the time integral of?
Old   June 10, 2011, 06:33
GAO
Andrew
Heat flow, for a problem with the heat flow
Old   June 10, 2011, 06:44
The time integral of a heat flow is the increase/decrease in heat. So you can do a volume integral of the heat in the domain. No need for a time integral.
Old   June 11, 2011, 03:48
GAO
Andrew
The task is next-passing the source of thermal radiation with respect to products with it must be removed a certain number of particles. The rate of passage may vary. The number of these particles we want to calculate. Or calculate the time spent checkpoint in a spot source, which is the same. It is for this and need the time integral.
Old   June 11, 2011, 07:28
I am sorry, I do not understand your last post. Can you write it again more clearly?
Old   June 12, 2011, 02:03
GAO
Andrew
Calculation of the integral over time is needed for next-motion 2 products relative to each other in time. We need to count how many times one overlaps another. That is needed some counter. The problem of heat.
If you need a figure for clarity, write to send you
Old   June 12, 2011, 09:05
I still don't know what you are describing. Please post an image.
Old   June 20, 2011, 02:59
GAO
Andrew
In principle, I need to find the time integral of the variable for Ansys not statsianary problem, the picture will not work. Is there a chance?
Old   June 20, 2011, 18:41
CFX cannot do time integrals in CEL so it is not easy to do in general.
The reason I am trying to understand what you are doing is often there is another way to implement it, but to suggest something I have to know what you are doing.
Can you tell me what variable you are trying to integrate? And what what is the termination condition you want to apply?
Old   June 23, 2011, 03:30
GAO
Andrew
http://upload.com.ua/get/902689092/1.JPG - shoulder movement
http://upload.com.ua/get/902689101/2.JPG - impact on the blade flow
Old   June 23, 2011, 07:16
I can't seem to view the images on your links. Please put them in the post on the forum, no need for external links.
Old   July 8, 2011, 06:26
GAO
Andrew
sorry, no access to the Internet. You are not hard to explain how it should look like?
Old   July 8, 2011, 07:04
Sorry, I did not understand that last post.
Old   July 8, 2011, 08:09
GAO
Andrew
I mean that in what form you would like to see the pictures?
Old   July 10, 2011, 06:44
Yes, please put the images on the forum.
Hydrostatic Pressure and Gravity miliante OpenFOAM Running, Solving & CFD 132 October 7, 2012 22:50
Computational time sunnysun OpenFOAM Running, Solving & CFD 5 March 16, 2009 03:32
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
AMG versus ICCG msrinath80 OpenFOAM Running, Solving & CFD 2 November 7, 2006 15:15
